NetGear 12-Port Gigabit Fiber Layer 2 Managed Switch
Quicklinx: 7YSDWS00 Mfr#: GSM7212F-100NES
Typical campus, warehouse or large building IP telephony, Wireless or Video-Surveillance deployments require flexible and affordable Fiber aggregation.
This 12-port Fiber platform with 12 combo Gigabit ports, provide PoE+ as well – whenever and wherever you want – even far from the MDF or typical wiring closet.
Because PoE deployments are always restrained by 100-meter copper limitation, such low-port count Fiber solution will simplify architectures and even power local PoE+ devices.
  • Enhanced connectivity
    With 12 combo Gigabit SFP ports and 4 10/100/1000 Ethernet interfaces, the NETGEAR M4100-12GF offers versatile connectivity options for a variety of network needs, ensuring high-speed data transfer and reliable connections.
  • Robust security features
    Equipped with RADIUS and TACACS+ authentication methods, alongside comprehensive support for IEEE standards including 802.1x and 802.3af, this switch provides a secure networking environment by preventing unauthorized access and ensuring data integrity.
  • Advanced network management
    Manageable via CLI, HTTP, SNMP, and RMON, the NETGEAR M4100-12GF allows for efficient network management and monitoring, enabling administrators to optimize performance and address issues proactively.
  • High performance
    With a switching capacity of 24 Gbps and a throughput of 17.8 Mpps, this switch is designed to handle demanding network environments, ensuring smooth data flow and reduced traffic bottlenecks.
  • Power over Ethernet (PoE) support
    The inclusion of PoE+ capability allows for the direct power supply to connected devices such as IP cameras and VoIP phones, simplifying the network infrastructure and reducing installation costs.
NETGEAR M4100-12GF - switch - 12 ports - Managed - rack-mountable
Switch - 12 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x combo Gigabit SFP + 4 x 10/100/1000
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 24 Gbps , Throughput: 17.8 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
VLAN support, DiffServ support, IPv6 support, STP support, RSTP support, MSTP support, QoS, Jumbo Frames support, DHCP server, PoE+, IPv4 support, LACP, DHCP client
IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
44 cm x 20.5 cm x 4.3 cm
3.7 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
8K entries
Jumbo Frame Support
Max Units In A Stack
8
Routing Protocol
Static IP routing
Authentication Method
RADIUS, TACACS+
4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB , 12 x SFP (mini-GBIC) , 12 x 1000Base-T RJ-45
Internal power supply
38.5 Watt
MTBF
239,032 hours
44 cm
20.5 cm
4.3 cm
3.7 kg
7YSD C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
7YSD C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
