NETGEAR M4300 24-port 10G SFP+ Managed Switch
Quicklinx: FG2RWS00 Mfr#: XSM4324FS-100NES
Type: 10 Gigabit Ethernet
Ports: 24
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
£2,267.59 ex VAT
£2,721.10 inc VAT
Half-Width 24x10G Stackable Managed Switch with 24xSFP+
  • Robust security
    Equipped with advanced encryption algorithms including 2048-bit RSA, 256-bit SHA-2, and 512-bit SHA-2, alongside RADIUS, Secure Shell v.2 (SSH2), and TACACS+ authentication methods, this switch ensures secure network access and data transmission.
  • High performance
    With a switching fabric bandwidth of 480 Gbps and a throughput of 357 Mpps, the NETGEAR M4300-24XF delivers exceptional performance for high-demand network environments.
  • Comprehensive network features
    Supports a wide range of networking features such as ARP support, BOOTP support, DHCP relay, DiffServ support, and more, providing flexibility and control over network traffic management.
  • Advanced Layer 3 switching
    Layer 3 advanced switching capabilities including policy-based routing (PBR), static IP routing, and support for routing protocols like OSPFv2, OSPFv3, and RIP-2, enabling efficient network routing and segmentation.
  • Efficient power management
    The internal power supply is 80 PLUS certified, ensuring efficient power usage with a maximum power consumption of 87.2 W, contributing to lower operational costs.
NETGEAR M4300-24XF - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10GBase-X + 2 x shared 10GBase-T
Performance
Switching fabric bandwidth: 480 Gbps , Throughput: 357 Mpps
Packet buffer size: 32 MB
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, OSPFv3, PIM-SSM, ECMP, policy-based routing (PBR), MLD, MSTP, RSTP
Remote Management Protocol
SNMP, RMON, Telnet, SNMP 3, HTTP, HTTPS, SSH-2, CLI, SCP, SFTP, DHCP, IPv4, IPv6, RSTP, TACACS+, RADIUS
BOOTP support, ARP support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, NSF, sFlow, PVST+, UDLD, LLDP support, DHCP relay, LACP, RSPAN, PVRST, MIB, dual firmware images, CoS, PTP, STRG, AAA, UDP, PIM
IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
AC 120/230 V
21.2 cm x 34.5 cm x 4.4 cm
3.56 kg
United States, Europe
NETGEAR lifetime warranty
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SHA, MD5, SSL 3.0, 2048-bit RSA, 256-bit SHA-2, 512-bit SHA-2, TLS 2.0
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
: 800 MHz
RAM
1 GB
Flash Memory
256 MB
24 x 10GBase-X SFP+ , 2 x 10GBase-T RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
Internal power supply
Installed Qty
1
Max Supported Qty
1
Power Provided
250 Watt
AC 120/230 V
87.2 Watt
80 PLUS Certification
80 PLUS
Front-to-rear airflow
MTBF
968,447 hours
SCCP
21.2 cm
34.5 cm
4.4 cm
3.56 kg
Limited warranty - lifetime
Ports: 24
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: £1500+
