Intelligent Edge M4100 series consists of 12 fully managed switches ranging from 8-port Fast Ethernet to 50-port Gigabit Ethernet. They are ideal for all organizations considering reliable, affordable and simple access layer switching with CLI scripting, Layer 3 static routing as well as PoE scalability. As a cost-effective component of converged voice, video and data networking solutions, NETGEAR M4100 series delivers a secure, intelligent edge in commercial buildings and large campus LAN environments. PoE (802.3af) and PoE+ (802.3at) versions of M4100 series are perfect for Wireless access points, IP telephony, CCTV and video-surveillance deployments.
Robust security
Equipped with RADIUS and TACACS+ authentication methods, this switch ensures secure network access control, providing peace of mind for sensitive data transmission. -
Comprehensive networking capabilities
Featuring advanced Layer 2+ switching, VLAN support, and static IPv4 routing, the NETGEAR M4100-50G-PoE+ facilitates efficient network segmentation and routing for optimized performance. -
Efficient power management
With a generous PoE budget of 380 W and support for PoE+, the switch efficiently powers multiple devices over the network, reducing cable clutter and energy costs. -
High-capacity networking
A 100 Gbps bandwidth and a MAC Address Table Size of 16K entries enable the handling of extensive data traffic, ensuring smooth and reliable network performance. -
Flexible installation options
The NETGEAR M4100-50G-PoE+ can be deployed in a desktop or rack-mounted setup, providing versatility to fit various spatial configurations and networking requirements.
- NETGEAR M4100-50G-PoE+ - switch - 50 ports - Managed - rack-mountable
- Switch - 50 ports - L2+ - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 50 x 10/100/1000 + 4 x shared SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 380 W
- Performance
- Bandwidth: 100 Gbps
- MAC Address Table Size
- 16K entries
- Routing Protocol
- Static IPv4 routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, CLI
- Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, RADIUS support, MLD snooping, IPv4 support, LACP support, DHCP client, MVR, CoS
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 31 cm x 4.32 cm
- 4.96 kg
- Localisation
- Canada, United States, Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 380 W
- Performance
- 16K entries
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- Status Indicators
- Port status, power, RPS (Redundant Power Supply), PoE, fan
- 48 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC) , 1 x USB - 4 pin USB Type A , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B
- Power Device
- Internal power supply
- Voltage Required
- 555.5 watt
- Redundant Power System (RPS) connector
- Rack Mounting Kit
- Included
- CISPR 22 Class A, cUL, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15 A, C-Tick Class A
- Localisation
- Software Included
- Drivers & Utilities
- 44 cm
- 31 cm
- 4.32 cm
- 4.96 kg
- 0 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.03 |
