NETGEAR Insight 48-Port Gigabit Ethernet Smart Cloud Switch
Quicklinx: DMM7WS00 Mfr#: GC752X-100EUS
Type: Gigabit Ethernet
Ports: 52
Managed: Yes
£347.71 ex VAT
£417.25 inc VAT
The NETGEAR Insight Managed Smart Cloud GC752X is the first 52-port Gigabit Ethernet Switch from NETGEAR with anytime, anywhere remote/cloud management. Using either the NETGEAR Insight mobile app or the Insight Cloud Portal you can easily setup, monitor and manage your Insight Managed Switches, Wireless Access Points, and business-class ReadyNAS storage. The NETGEAR GC752X features 48 copper Gigabit Ethernet ports, 2 SFP 1G and 2 SFP+ 10G fiber ports for maximum flexibility and connectivity in your network. With its remote cloud manageability, and advanced L2+/L3 Lite features, it's the most versatile switch on the market for any environment!
  • 48-port Gigabit copper + 2-port Gigabit SFP fiber + 2-port 10-Gigabit SFP+ ports
    All-inclusive connectivity with copper and 1G/10G fiber ports.
  • Local and remote monitoring and management with NETGEAR Insight app
    Setup, monitor and manage your network from anywhere with NETGEAR Insight iOS and Android mobile app with Insight Managed Switches, Wireless Access Points, and ReadyNAS storage devices.
  • Your choice of management interface with NETGEAR Insight Cloud Portal
    Monitor and manage your network from an intuitive cloud portal with advanced configuration features, as well as from the palm of your hand with the Insight mobile app.
  • Remote/Cloud-managed advanced switching made affordable
    Fully-integrated cloud-manageable devices; remote/cloud monitoring and management from the app is free for first two devices; after that, a subscription is required per additional device (no additional hardware required).Full duplexing, non-blocking switching with 140Gbps line rate fabricGet all the bandwidth you're paying for from 50 ports of Gigabit and 2 ports of 10-Gigabit connectivity.
NETGEAR Smart GC752X - switch - 52 ports - smart - rack-mountable
Switch - 52 ports - L3 - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x Gigabit SFP (uplink) + 2 x 10 Gigabit SFP+ (uplink)
Performance
Fabric throughput: 140 Gbps , Forwarding performance (64-byte packet size): 104.2 Mpps
ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512 , IPv4 routes (static): 32 , IPv6 routes (static): 31
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
ARP support, IGMP snooping, Syslog support, SPI, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, LACP support, LLDP support, DHCP relay, DHCP client, Energy Efficient Ethernet, MVR, dual firmware images, SPQ, NDP, 2MB packet buffer, loop prevention, security lock slot (cable lock sold separately), ToS, DSCP support, cable test, administrator's password, ICMP IRDP, DNS client, 1 fan, guest access, WRR, loopback detection
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
44 cm x 22.4 cm x 4.4 cm
3.16 kg
Europe
5-year warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
MD5, TLS 1.0, SSL 3.0, PEAP
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
1 Cortex-A9: 400 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Power, status, fan, link/activity/speed
48 x 10/100/1000 Base-T RJ-45 , 2 x 1000Base-X SFP uplink , 2 x 10GBase-X SFP+ uplink , USB
Internal power supply
43.9 Watt
Rubber feet
Rack Mounting Kit
Included
MTBF
1,360,115 hours
CCC, UL 60950-1 Second Edition, KCC, K60950-1, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class A, GB 4943.1-2011, EN 55024:2010+A1:2015, KN32, KN35, BSMI CNS13438:2006 Class A, EN 55032:2012+AC:2013 Class A, CNS 14336-1, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2015 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
44 cm
22.4 cm
4.4 cm
3.16 kg
Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 52
Managed: Yes
Brand: NETGEAR
