NETGEAR GS348T 48-port 4XSFP Smart Switch
Quicklinx: F63SWS00 Mfr#: GS348T-100EUS
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
£233.43 ex VAT
£280.11 inc VAT
NETGEAR Smart Managed Pro S350 series consists of five switch models, including 8-, 24- and 48-port Gigabit Ethernet switches and 8-, and 24-port Gigabit Ethernet PoE+ switches with 2 or 4 SFP ports for fiber uplinks, offering powerful Layer 2 features, enhanced performance and ease of use. They are purposely designed for converged networks where voice, video, data are all carried on a single network platform. Advanced features such as L2/L3/L4 Access Control Lists (ACLs), Quality of Service (QoS), Link Aggregation Control Protocol (LACP) and Spanning Tree Protocol (STP) will ensure a high-speed and highly secured network environment for your business.
  • Robust security
    With support for RADIUS and TACACS+ authentication methods, alongside a comprehensive Access Control List (ACL), the NETGEAR Smart GS348T ensures secure network access and precise control over user permissions.
  • Efficient performance
    Equipped with a 104 Gbps switch fabric speed and a forwarding performance of 77.3 Mpps, this switch is designed to handle substantial data traffic, ensuring efficient data flow across the network.
  • Extensive connectivity
    Featuring 48 RJ-45 connectors for 1000Base-T and 4 SFP slots for 1000Base-X connections, the GS348T offers versatile connectivity options for a wide range of network requirements.
  • Advanced network features
    From VLAN support to Quality of Service (QoS) and port mirroring, the GS348T comes packed with features to manage traffic, prioritize services, and secure your network infrastructure.
  • Easy management
    Manageable via HTTP, HTTPS, SNMP, and more, the GS348T provides a flexible and intuitive interface for configuring, managing, and monitoring the network, simplifying network administration tasks.
NETGEAR Smart GS348T - switch - 48 ports - smart - rack-mountable
Switch - 48 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x SFP
Performance
Switch fabric speed: 104 Gbps ¦ Forwarding performance (64-byte packet size): 77.3 Mpps
ACL: 100 ¦ IGMP multicast groups: 512 ¦ Priority queues: 8 ¦ DHCP snooping entries: 8000
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, LACP support, DHCP client, dual firmware images, SPQ, CoS, SP, ToS, DSCP support, 1.5MB packet buffer, cable test, rate limit, IGMP querier, 1 fan, Voice VLAN, VLAN management, Guest VLAN, WRR, MAC based VLAN, Auto VoIP, MAC lockdown, SNTP client
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
44 cm x 20.6 cm x 4.3 cm
3.05 kg
Europe
5-year warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
TLS
Authentication Method
RADIUS, TACACS+
: 400 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Power, link/activity, fan, speed
48 x 1000Base-T RJ-45 ¦ 4 x 1000Base-X SFP
Internal power supply
Installed Qty
1
39.1 watt
Rubber feet
Rack Mounting Kit
Included
MTBF
1,271,842 hours
BSMI CNS 13438 Class A, EN 60950, UL 1950, SCC, CNS 14336, EN 61000-3-3:2013, EN 55024:2010, YD/T993-1998, FCC CFR47 Part 15 A, GB 4943.1-2011, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, CISPR 32:2012, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2013 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
44 cm
20.6 cm
4.3 cm
3.05 kg
Limited warranty - 5 years ¦ Limited warranty - replacement - 5 years - response time: next business day ¦ Technical support - phone consulting - 90 days
45 °C
95% (non-condensing)
Ports: 48
Managed: Yes
Brand: NETGEAR
