NETGEAR GS324TP 24-port 2xSFP POE+ Smart Switch
Quicklinx: F63RWS00 Mfr#: GS324TP-100EUS
NETGEAR Smart Managed Pro S350 series consists of five switch models, including 8-, 24- and 48-port Gigabit Ethernet switches and 8-, and 24-port Gigabit Ethernet PoE+ switches with 2 or 4 SFP ports for fiber uplinks, offering powerful Layer 2 features, enhanced performance and ease of use. They are purposely designed for converged networks where voice, video, data are all carried on a single network platform. Advanced features such as L2/L3/L4 Access Control Lists (ACLs), Quality of Service (QoS), Link Aggregation Control Protocol (LACP) and Spanning Tree Protocol (STP) will ensure a high-speed and highly secured network environment for your business.
  • Enhanced security
    With support for Access Control List (ACL), DHCP snooping, and advanced encryption algorithms like TLS, this switch ensures a secure network environment, preventing unauthorized access and protecting sensitive data.
  • Efficient performance
    Featuring a switch fabric speed of 52 Gbps and a forwarding performance of 38.6 Mpps, the NETGEAR Smart GS324TP delivers efficient handling of data across the network, ensuring high-speed connectivity and reliable performance.
  • Comprehensive connectivity
    Equipped with 24 PoE+ ports and 2 SFP ports, this switch offers versatile connection options for various devices, including high-power wireless access points, surveillance cameras, and VoIP phones, while ensuring compatibility with fiber connections.
  • Intelligent network management
    Smart features like Quality of Service (QoS), VLAN support, and port mirroring enable sophisticated management of network traffic, ensuring optimal performance for critical applications and services.
  • Durable and reliable
    With a mean time between failures (MTBF) of over 1.3 million hours and a comprehensive set of compliance standards, this switch is built for longevity and dependable operation in diverse environments.
NETGEAR Smart GS324TP - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
190 W
Performance
Switch fabric speed: 52 Gbps , Forwarding performance (64-byte packet size): 38.6 Mpps
ACL: 100 , IGMP multicast groups: 512 , Priority queues: 4 , DHCP snooping entries: 8000
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, LACP support, DHCP client, 512KB packet buffer, dual firmware images, SPQ, CoS, SP, ToS, DSCP support, 2 fans, cable test, rate limit, IGMP querier, Voice VLAN, VLAN management, Guest VLAN, WRR, MAC based VLAN, Auto VoIP, MAC lockdown, SNTP client
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
33 cm x 20.6 cm x 4.3 cm
2.69 kg
Europe
5-year warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
190 W
Performance
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
TLS
Authentication Method
RADIUS, TACACS+
: 800 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Power, PoE, link/activity, fan, speed
24 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP
Internal power supply
Installed Qty
1
229.9 watt
Rubber feet
Rack Mounting Kit
Included
MTBF
1,328,429 hours
BSMI CNS 13438 Class A, EN 60950, UL 1950, SCC, CNS 14336, EN 61000-3-3:2013, EN 55024:2010, YD/T993-1998, FCC CFR47 Part 15 A, GB 4943.1-2011, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, CISPR 32:2012, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2013 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
33 cm
20.6 cm
4.3 cm
2.69 kg
Limited warranty - 5 years , Limited warranty - replacement - 5 years - response time: next business day , Technical support - phone consulting - 90 days
45 °C
95% (non-condensing)
