NETGEAR GIGE 8-port Unmanaged with Uplinks
Quicklinx: D5BYWS00 Mfr#: GS110EMX-100UKS
NETGEAR GS110EMX Managed Switch. Perfect for a desktop and rack-mountable or even wall-mountable.
  • Robust performance
    With a switching capacity of 56 Gbps, the NETGEAR Plus GS110EMX delivers efficient handling of data across its network, ensuring high-speed connectivity for all connected devices.
  • Versatile connectivity
    Equipped with 8 ports of 1000Base-T and 2 uplink ports supporting up to 10G speeds, this switch offers a wide range of connection options for various networking needs, from standard gigabit to multi-gigabit speeds.
  • Advanced networking features
    Features such as VLAN Tagging, Link Aggregation, and IGMP snooping provide enhanced network segmentation, increased bandwidth, and improved traffic management, making the GS110EMX a powerful tool for any network.
  • Efficient power usage
    The external power adapter and a power consumption operational value of 15.6 watts make this switch an energy-efficient choice for businesses looking to optimize their power usage.
  • Flexible installation options
    With its fanless design and included rack mounting kit, the NETGEAR Plus GS110EMX can be easily deployed in a variety of environments, ensuring quiet operation and flexible placement.
NETGEAR Plus GS110EMX - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - smart
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
8 x 1000Base-T + 2 x 100/1000/2.5G/5G/10G (uplink)
Performance
Fabric throughput: 56 Gbps , Latency (10 Gbps): < 3 µs , Latency (1000 Mbps): < 4 µs , Latency (100 Mbps): < 7 µs , Packet forwarding rate: 41.664 Mfps
MAC address entries: 16000 , Priority queues: 8 , IGMP multicast groups: 128 , VLANs supported: 64
Jumbo Frame Support
10240 bytes
Trunking, IGMP snooping, DoS attack prevention, port mirroring, Quality of Service (QoS), Jumbo Frames support, fanless, 128KB packet buffer, LACP support, DHCP client, Energy Efficient Ethernet, loop prevention, DiffServ Code Point (DSCP) support, cable test, Link Aggregation, Voice VLAN, ingress rate limiting, VLAN Tagging, port-based VLAN, egress rate limiting, port-based QoS
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
23.6 cm x 10.2 cm x 2.7 cm
750 g
United Kingdom
ProSAFE lifetime warranty
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
10240 bytes
Status Indicators
Power, link/activity/speed
External power adapter
Installed Qty
1
15.6 Watt
Rubber feet, wall mounting kit
Rack Mounting Kit
Included
CB, UL 60950-1, KC, EAC, CNS 13438, EN 61000-3-3:2013, EN 61000-3-2:2014, FCC CFR47 Part 15 B Class B, EN 55024:2010+A1:2015, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, CISPR 32:2012, CAN/CSA-C22.2 No. 60960-1-07, ICES-003:2016 issue 6 Class B, AS/NZS CISPR 32:2013 Class B, EN 55032:2015+AC:2016, CISPR 32:2015+COR1:2016, VCCI-CISPR 32:2016 Class B, AS/NZS CISPR32:2015 Class B, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
United Kingdom
23.6 cm
10.2 cm
2.7 cm
750 g
Limited warranty - replacement - lifetime , Technical support - on-site
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
