NETGEAR GC108PP 8-port Insight Managed Hi-POE+ Gigabit Ethernet Swit
Quicklinx: FMLYWS00 Mfr#: GC108PP-100UKS
Insight Managed Smart Cloud Switches are the advanced switches from NETGEAR with anywhere configuration and management. Using either the NETGEAR Insight app on your mobile device or tablet, or the Insight Cloud Portal from your PC, Mac, or tablet, you can quickly discover, setup, monitor and manage your Smart Cloud Switches from anywhere in the world! With their remote cloud manageability, sleek design silent or whisper-quiet operation, they are the most versatile switches in the market for any environment. Whether at home, out of the office or on a business trip, you can still manage and monitor your network as if you were right there.
  • Remote monitoring and management from the palm of your hand
    With the NETGEAR Insight app, you can setup, manage, and monitor your networks from anywhere, anytime, from the palm of your hand on your phone or tablet! Or, for a larger screen experience, you can use the Insight Cloud Portal from your PC, Mac, or tablet web browser.
  • Network-centric configuration and management
    NETGEAR Insight Managed Switches and Wireless Access Points using the NETGEAR Insight app allow for cross-device automated configuration of VLANs, QoS, ACLs, and LAGs. Auto-join and configure (zero-touch provisioning) allows for additional devices added seamlessly.
  • Fully-integrated cloud-manageable devices
    NETGEAR Insight Managed switches are fully-integrated, cloud-manageable, plug-and-play devices. Just connect to your network and without any setup, they're passing traffic. For configuration setup, management, and monitoring, you can use the Insight mobile app on your mobile device or the Insight Cloud Portal from your PC, Mac, or tablet web browser. No additional cloud controller, appliance, network manager, or on-premise cloud server necessary.
  • Clean, sleek silent design
    Insight Managed switches have a modern, clean design, with at-a-glance power/cloud and and PoE max LEDs for quick status monitoring. Additionally, on-port LEDs for link/activity and PoE power allow for port-specific connectivity monitoring.
NETGEAR Smart GC108PP - switch - 8 ports - smart
Switch - 8 ports - L3 Lite - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
126 W
Performance
Fabric throughput: 16 Gbps , 1 Gbps copper latency (64-byte packets): 3460 µs , Packet buffer size: 512 KB , Packet forwarding rate: 11.9 Mfps , 1 Gbps copper latency (1518-byte packets): 3360 µs , 1 Gbps copper latency (9216-byte packets): 3560 µs
ACL: 100 , VLANs supported: 64 , ARP entries: 512 , IPv4 routes (static): 32 , Priority queues: 8 , IGMP multicast groups: 256
MAC Address Table Size
8K entries
Jumbo Frame Support
10000 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv4 routing, MLDv2, MLD, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, TFTP, IPv4, IPv6
Flow control, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, fanless, LACP support, DHCP client, Multicast VLAN Registration (MVR), dual firmware images, loop prevention, Strict Priority (SP), cloud managed, Type of Service (ToS), DiffServ Code Point (DSCP) support, cable test, ICMP Router Discovery Protocol (IRDP), DNS client, LLDP-MED, Private VLAN, Guest VLAN, protected ports, Energy-Efficient Ethernet (EEE), PoE timer, Weighted Round Robin (WRR), VLAN Tagging, Unknown Storm Control, security slot (Kensington security lock compatible)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, UPnP
18.8 cm x 11 cm x 2.7 cm
520 g
United Kingdom
5-year warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
126 W
Performance
8K entries
Jumbo Frame Support
10000 bytes
Routing Protocol
Encryption Algorithm
TLS 1.0
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
: 500 MHz
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Power, PoE, link/activity/speed, cloud
8 x 10/100/1000 Base-T RJ-45 PoE+
External power adapter
128.4 Watt
MTBF
2,635,395 hours
BSMI, BSMI CNS 13438 Class A, UL 60950-1 Second Edition, KCC, RCM, EN 61000-3-3:2013, YD/T993-1998, FCC CFR47 Part 15 B Class A, GB 4943.1-2011, EN 55024:2010+A1:2015, KN32, KN35, CNS 14336-1, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, CISPR 32:2015 Class A, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2015 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, GB/T9254-2008, EN 55032:2015+AC:2016 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
United Kingdom
18.8 cm
11 cm
2.7 cm
520 g
Limited warranty - replacement - 5 years - response time: next business day , Limited warranty - replacement - power supply - 2 years - response time: next business day , Technical support - 90 days
45 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
