NETGEAR 24-Port 10-Gigabit/Multi-Gigabit Ethernet
Quicklinx: D7YKWS00 Mfr#: XS724EM-100EUS
Type: 10 Gigabit Ethernet
Ports: 24
Data Transfer Rate: [N/A]
Managed: Yes
POE: [N/A]
£1,532.50 ex VAT
£1,839.00 inc VAT
Through an intuitive GUI it provides easy, reliable and affordable connectivity with VLAN, QoS, LAG and IGMP management capabilities. The XS724EM also include the full set of Smart Managed Plus software features such as traffic prioritization and link aggregation.
  • Robust performance
    With a fabric throughput of 480 Gbps and forwarding performance capable of handling 240 Mbps with 64-byte packet size, the NETGEAR Plus XS724EM ensures efficient data flow and high-speed connectivity across the network.
  • Comprehensive connectivity
    Equipped with 24 ports supporting 100/1000/2.5G/5G/10GBase-T and 2 combo 10 Gigabit SFP+ ports, this switch offers versatile connectivity options for a wide range of devices and network requirements.
  • Advanced network features
    Features such as VLAN support, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), and IGMP snooping provide enhanced network management and improved data traffic control.
  • Efficient operation
    Energy Efficient Ethernet (EEE) and a power consumption of just 150.52 W during operation make the XS724EM an economical choice for energy-conscious environments.
  • Durable and reliable
    Designed for longevity with an MTBF of 830,493 hours and equipped with 3 fans for optimal cooling, ensuring the switch operates reliably even in demanding conditions.
NETGEAR Plus XS724EM - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
22 x 100/1000/2.5G/5G/10GBase-T + 2 x combo 10 Gigabit SFP+
Performance
Fabric throughput: 480 Gbps , Forwarding performance (64-byte packet size): 240 Mbps
Priority queues: 8 , IGMP multicast groups: 128
MAC Address Table Size
32K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
HTTP, TFTP
VLAN support, IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, QoS, LACP, DHCP client, Energy Efficient Ethernet, loop prevention, Multicast filtering function, CoS, ToS, DSCP support, 3 fans, 3MB packet buffer, cable test, administrator's password, WRR, VLAN Tagging, port trunking
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
AC 120/230 V (50 - 60 Hz)
44 cm x 20.4 cm x 4.3 cm
3.72 kg
Europe
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
HTTP, TFTP
Status Indicators
Power, link/activity/speed
24 x 100/1000/2.5G/5G/10GBase-T RJ-45 , 2 x 10GBase-X SFP+
Internal power supply
150.52 Watt
Rack Mounting Kit
Included
MTBF
830,493 hours
UL 60950-1, KC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class A, EN 55032:2012+AC:2013 Class A, CNS 14336-1, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, EN 61000-3-2:2014 Class A, CAN/CSA-C22.2 No. 60960-1-07, AS/NZS CISPR32:2013 Class A, EN 6100-3-3:2013, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, VCCI-CISPR 32:2016, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
44 cm
20.4 cm
4.3 cm
3.72 kg
Limited warranty - lifetime
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 24
Managed: Yes
POE: [N/A]
Brand: NETGEAR
Price Range Ex VAT: £1500+
