The NETGEAR ProSAFE GS408EPP Easy-Mount 8-port Gigabit Ethernet PoE+ Web Managed Switch with 8 PoE+ ports features a unique "Virtually Anywhere"mounting system that allows to install more PoE+ ports exactly where you need them. The unique mounting system allows you to put the Easy Mount Switch up in the ceiling, strapped to a pole, mounted under a desk or tabletop, making it the perfect switch for deploying Wireless APs, Pan/Tilt/Zoom and fixed IP Cameras, VoIP Phones, access-limited security door locks or any other IoT PoE-powered devices. Should you decide to rack mount the GS408EPP switch, you can save space by installing two switches in just a single 1U slot. As a member of the NETGEAR Web Managed (Plus) Switch family, the GS408EPP also includes the full set of software features such as traffic prioritization, VLANs, QoS, Port Trunking/Link Aggregation and PoE power allocation. The GS408EPP also features Energy Efficient Ethernet (IEEE 802.3az) for maximum power savings.
Robust performance
With a bandwidth of 16 Gbps and low latency across various packet sizes, this switch ensures efficient data flow and connectivity for all connected devices. -
Comprehensive PoE support
Equipped with 8 PoE+ ports and a total PoE power budget of 124 W, the GS408EPP allows for flexible deployment of network devices such as IP cameras, VoIP phones, and wireless access points without the need for additional power sources. -
Advanced networking features
Features like VLAN support, Quality of Service (QoS), IGMP snooping, and Link Aggregation enhance network management, improve security, and ensure optimal performance for traffic prioritization. -
Versatile mounting options
Designed for adaptability, this switch can be placed on a desktop, mounted on a wall, pole, or rack, making it an ideal choice for various installation environments. -
Energy efficient
Incorporates Energy Efficient Ethernet (IEEE 802.3az) for reduced power consumption, making it an eco-friendly addition to any network infrastructure.
- NETGEAR Plus GS408EPP - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - Managed
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE+)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 124 W
- Performance
- Bandwidth: 16 Gbps , Latency (10 Mbps): < 76.9 µs , Latency (100 Mbps): < 9.1 µs , Latency (1000Base-T): < 2.7 µs , Forwarding performance (64-byte packet size): 11.9 Mfps
- Capacity
- Virtual interfaces (VLANs): 64 , IGMP groups: 128 , Priority queues: 4
- MAC Address Table Size
- 4K entries
- Jumbo Frame Support
- 9000 bytes
- Routing Protocol
- IGMP
- Remote Management Protocol
- HTTP, TFTP
- Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, firmware upgradable, vertical mounting, Quality of Service (QoS), horizontal mounting, Jumbo Frames support, pole mountable, DHCP client, Energy Efficient Ethernet, loop prevention, 192KB packet buffer, Multicast filtering function, Class of Service (CoS), tagged VLAN, Denial of Service (DoS), Type of Service (ToS), DiffServ Code Point (DSCP) support, cable test, Link Aggregation, Virtually Anywhere Mounting, Voice VLAN
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
- 38 cm x 10 cm x 4.3 cm
- 1.6 kg
- Localisation
- Latin America, North America, Europe
- ProSAFE lifetime warranty
- Enclosure Type
- Desktop, rack-mountable, wall-mountable, pole-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 124 W
- Performance
- Capacity
- 4K entries
- 9000 bytes
- Routing Protocol
- IGMP
- HTTP, TFTP
- Status Indicators
- Power, PoE, fan, link/activity/speed
- 8 x 1000Base-T RJ-45 PoE+ - 124 W
- Power Device
- Internal power supply
- Rack Mounting Kit
- Included
- MTBF
- 2,715,369 hours
- AS/NZS 60950-1, UL 60950-1, CAN/CSA C22.2 No. 60950-1-07, KC, ANSI C63.4, EN 60950-1:2006, EAC, CNS 13438, IEC 60950-1:2005, EN 55024:2010, AS/NZS CISPR22:2009+A1:2010, CISPR 22:2008, FCC CFR47 Part 15 B Class A, EN 6100-3-3, EN55022:2010 + AC:2011 Class A, ICES-003 issue 6 Class A, VCCI V-4/2012.04, VCCI V-3/2015.04 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- Software Included
- ProSAFE Plus Configuration Utility
- 38 cm
- 10 cm
- 4.3 cm
- 1.6 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - e-mail consulting
- 0 °C
- 50 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
