NETGEAR 5P POE Gigabit Unmanaged Switch
Quicklinx: CZPHWS00 Mfr#: GS305P-100UKS
5 Gigabit Ethernet ports
4 PoE+ ports with 63W total power budget
Simple plug-and-play setup with no software to install or configuration needed
Supports desktop or wall mount placement
Silent operation ideal for noise sensitive environment
  • Efficient power management
    The GS305P features a robust 55.5 W PoE budget, providing flexible power options to power devices such as IP cameras, VoIP phones, and wireless access points directly through the network cables, eliminating the need for additional power supplies and reducing clutter.
  • Versatile connectivity options
    With five 10/100/1000 Mbps ports, including four PoE ports, this switch offers ample bandwidth and flexibility to support a variety of network configurations and devices, ensuring a high-speed and reliable network connection for all connected devices.
  • Easy installation
    Designed for convenience, the GS305P supports Plug-and-Play installation with no software or configuration required. Its compact form factor allows for desktop or wall-mounted setup, making it an ideal choice for small to medium-sized businesses or home offices.
NETGEAR GS305P - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000 (4 PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
55.5 W
Fanless
3-year warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
55.5 W
Fanless
Status Indicators
Power, PoE, link/activity
4 x 1000Base-T RJ-45 PoE , 1 x 1000Base-T RJ-45
Plug and Play
Limited warranty - 3 years
