NetGear 24-Port Gigabit PoE Layer 2 Managed Switch
Quicklinx: 7YSHWS00 Mfr#: GSM7224P-100NES
IP telephony, Wireless or Video-Surveillance deployments may require higher PoE+ density in wiring closets. This 24-port PoE+ platform is 802.3af full power – with supplemental 802.3at full power capacity – yet affordable when compared to typical competitive solutions with even less PoE budget. When associated to GSM7212F, PoE deployments can be much Smarter with the right number of PoE ports – whenever and wherever you want.
  • Intelligent Edge
    Combining superior resiliency and advanced security even far from the wiring closet, the switches provide comprehensive Layer 2 and Lite Layer 3 switching, including 16K MAC table size, 64 routing interfaces and 16 static routes.
  • Unified Communications - Voice over IP
    The NETGEAR ProSafe "Intelligent Edge" simplifies converged data deployments with state-of-the-art capabilities. CoS Layer 2 prioritization and DiffServ Layer 3 & 4 policies allow for 1Kbps ingress and egress TCP/UDP granularity. LLDP-MED (Media Endpoint Discovery) automatically configures IP phones QoS and VLAN settings.
  • Unified Communications - video streams
    IGMP filtering and querier ensure multicast streams are only delivered to interested receivers, preventing flooding even without a dedicated multicast router. When receivers are in different VLANs, Multicast VLAN registration (MVR) uses a dedicated multicast VLAN to forward multicast streams and avoid duplication for clients in different VLANs.
  • Outstanding value
    With its high-value price point, industry-standard command line interface (CLI) and single-pane-of-glass NMS200 management platform (mass-configuration support), NETGEAR ProSafe "Intelligent Edge" yields a high return on investment.
NETGEAR M4100-24G-PoE+ - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x shared SFP
Power Over Ethernet (PoE)
PoE+
Performance
Switching capacity: 48 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
VLAN support, DiffServ support, IPv6 support, STP support, RSTP support, MSTP support, QoS, Jumbo Frames support, DHCP server, PoE+, IPv4 support, LACP, DHCP client
IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
44 cm x 20.5 cm x 4.3 cm
3.7 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
8K entries
Jumbo Frame Support
Max Units In A Stack
8
Routing Protocol
Static IP routing
Authentication Method
RADIUS, TACACS+
24 x 10Base-T/100Base-TX/1000Base-T RJ-45 PoE+ , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB , 4 x SFP (mini-GBIC) - SFP
Internal power supply
38.5 watt
MTBF
239,032 hours
44 cm
20.5 cm
4.3 cm
3.7 kg
7YSH C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
