The NETGEAR 24-Port Gigabit Ethernet Switch with simple plug-and-play, compact desktop design, and auto-sensing ports provides easy, reliable, and affordable connectivity for your home or small office network. A rugged metal enclosure, silent, fanless design, and both wall-mount and rack-mount kits allow for convenient deployment to build out your SOHO network. Auto-MDI/MDIX (eliminating the need for crossover cables), jumbo packet support, auto-negotiation for automatic connection at highest speeds, non-blocking switching architecture for maximum throughput, and energy-efficient technology for power savings (IEEE 802.3az and short cable power reduction) make the GS324 the perfect switch for the SOHO environment.
Robust performance
With a bandwidth of 48 Gbps and forwarding performance capable of handling up to 1,448,000 packets per second, this switch ensures efficient data flow and high-speed connectivity for all connected devices. -
Versatile connectivity
Equipped with 24 RJ-45 connectors supporting 1000Base-T for Gigabit Ethernet, this switch offers ample ports for connecting multiple devices, making it ideal for expanding your network. -
Energy-efficient design
Features like ENERGY STAR Ethernet (EEE) and a fanless design not only reduce operational costs but also contribute to a quieter, more environmentally friendly workspace. -
Easy installation
The NETGEAR SOHO GS324 comes with a rack mounting kit, and its form factor allows for desktop, rack-mountable, or wall-mountable setups, offering flexibility in installation according to your space requirements. -
Enhanced network management
Quality of Service (QoS) support ensures critical data is prioritized, while auto-negotiation and auto-uplink adjust for the optimal link speed and routing, improving overall network efficiency.
- NETGEAR SOHO GS324 - switch - 24 ports - unmanaged - rack-mountable
- Switch - 24 ports - unmanaged
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000
- Performance
- Bandwidth: 48 Gbps , Forwarding performance (64-byte packet size): 1448000 packets per second , Latency (64-byte packets): 4.7 µs
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9216 bytes
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS, fanless, 512KB packet buffer, EEE
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50 - 60 Hz)
- 25.2 cm x 18 cm x 4.4 cm
- 1.31 kg
- 3-year warranty
- Enclosure Type
- Desktop, rack-mountable, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000
- Performance
- 8K entries
- 9216 bytes
- Status Indicators
- Power, link/activity
- 24 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 11.1 Watt
- Power Consumption Stand by
- 8.47 Watt
- Rack Mounting Kit
- Included
- Plug and Play
- 25.2 cm
- 18 cm
- 4.4 cm
- 1.31 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
