NetGear 24 Port Gigabit Ethernet PoE Plus Switch
Quicklinx: 99Q1WS00 Mfr#: JGS524PE-100EUS
Today's growing businesses demand and rely more on their network to carry out mission-critical business activities. Companies are putting more network traffic and applications on their Ethernet infrastructure. For example, the increasing deployments of VoIP phones and IP cameras require more than simple Plug-and-Play connectivity. It needs the network intelligence to separate the voice and video traffic from data, and prioritize them accordingly. Additionally, Internet-based applications such as Hotmail and Google Calendaring have made keeping the network up a business-critical need. However, companies do not necessarily have more money or advanced training to deal with complex managed switches. NETGEAR's ProSafe Plus switches meet this growing need by providing fundamental network features that will help optimize the performance of business networks. ProSafe Plus switches also offer traffic monitoring for users to observe traffic behavior. If there are connectivity issues, these switches can identify and even locate connection problems via cable diagnostic test. To optimize traffic through the switches, ProSafe Plus switches offer both port and tag-based prioritization to keep latency-sensitive traffic moving ahead of less critical packets. Also, ProSafe Plus switches offer port and 802.1Q-based VLAN as a means of improving security and network performance. ProSafe Plus switches are an upgrade from the Plug-and-Play unmanaged switch, delivering great value for empowering your network, delivering great value to the end user.
  • Enhanced connectivity
    With 24 RJ-45 connectors supporting 1000Base-T for high-speed Gigabit Ethernet, the NETGEAR Plus JGS524PE ensures efficient connectivity and network performance. The inclusion of Power over Ethernet (PoE) across 12 ports simplifies network installation and maintenance by eliminating the need for additional power cables.
  • Robust security features
    The switch is equipped with advanced security measures including DoS attack prevention, broadcast storm control, and IGMP snooping. These features work together to protect the network from unauthorized access and ensure uninterrupted service.
  • Optimized network performance
    Quality of Service (QoS) and flow control capabilities allow for prioritization of network traffic, ensuring that critical applications receive the bandwidth they need. Port mirroring further aids in network troubleshooting and monitoring, making it easier to identify and resolve issues.
  • Flexible installation options
    Designed for versatility, the NETGEAR Plus JGS524PE can be placed on a desktop or mounted in a rack, providing flexibility in setup based on your space requirements and preferences.
  • Efficient power management
    With a total PoE budget of 100 W, this switch can power multiple devices through its Ethernet cables, reducing clutter and saving on energy costs. The internal power supply ensures a reliable power source for the switch and connected devices.
NETGEAR Plus JGS524PE - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE) + 12 x 10/100/1000
Power Over Ethernet (PoE)
PoE
PoE Budget
100 W
Performance
Bandwidth: 48 Gbps
MAC Address Table Size
16K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Flow control, IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, QoS, Jumbo Frames support, DHCP client, Energy Efficient Ethernet, 768KB packet buffer, SP, ToS, cable test, Link Aggregation, 1 fan, WRR, port trunking
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
32.8 cm x 17 cm x 4.3 cm
1.84 kg
Europe
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
100 W
Performance
Bandwidth: 48 Gbps
16K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
Status Indicators
Port transmission speed, power, PoE, link/activity, fan
12 x 1000Base-T RJ-45 , 12 x 1000Base-T RJ-45 PoE
Internal power supply
Rack Mounting Kit
Included
MTBF
643,506 hours
VCCI, C-Tick, cUL, EN 60950, EN55022, UL 1950, EN55024, CSA 22.2 No. 950, CISPR 22, EN50082-1, CCC, FCC Part 15, IEC 950
Europe
Software Included
Drivers & Utilities
32.8 cm
17 cm
4.3 cm
1.84 kg
Limited warranty - lifetime
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
99Q1 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
99Q1 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.75
99Q1 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
