The NETGEAR XS712Tv2 10-Gigabit Ethernet Smart Managed Pro Switch brings the second generation of 10-Gigabit Copper switching to SMBs. The XS712Tv2 is a powerful Smart Managed Switch that includes 12 ports of 10-Gigabit connectivity (12 copper with 2 shared combo copper/SFP+ Fiber ports). NETGEAR 10-Gigabit Smart Managed Pro Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. Advanced features include Layer 3 static routing, IPv6, DiffServ QoS, LACP link aggregation and Spanning Tree.
Robust security
With support for Access Control List (ACL), 802.1x authentication, and both RADIUS and TACACS+, the NETGEAR Smart XS712T ensures secure network access and management, safeguarding your data from unauthorized access. -
Efficient performance
Featuring a 240 Gbps switching fabric bandwidth and a forwarding performance of 178.5 Mpps, this switch is engineered to handle high volumes of traffic, ensuring efficient data flow across the network. -
Advanced networking
Equipped with Layer 2+ switching capabilities, support for multiple VLANs, and advanced Quality of Service (QoS) features, the NETGEAR Smart XS712T facilitates complex network architectures and prioritizes traffic for critical services. -
Comprehensive connectivity
With 12 10GBase-T ports and 2 shared 10 Gigabit SFP+ ports, this switch offers flexible connection options for a variety of devices, supporting high-speed network infrastructures. -
Durable and reliable
Designed for longevity with a mean time between failures (MTBF) of 938,178 hours and a rack-mountable form factor, the NETGEAR Smart XS712T is a dependable solution for any business network.
- NETGEAR Smart XS712T - v2 - switch - 12 ports - smart - rack-mountable
- Switch - 12 ports - L2+ - smart
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 12 x 10GBase-T + 2 x shared 10 Gigabit SFP+
- Performance
- Switching fabric bandwidth: 240 Gbps , Forwarding performance (64-byte packet size): 178.5 Mpps
- Capacity
- ACL: 100 , Virtual interfaces (VLANs): 256 , ARP entries: 738 , Priority queues: 8 , IPv4 routes: 32 , IPv6 routes: 32 , IGMP multicast groups: 512 , DHCP snooping entries: 8000
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
- Flow control, auto-negotiation, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, LLDP support, LACP, Energy Efficient Ethernet, MVR, GVRP, dual firmware images, 2MB packet buffer, static routing, Multicast filtering function, SP, 802.1x authentication, VoIP support, DSCP support, 2 fans, Protocol-based VLANs support, NAS support, cable test, ICMP IRDP, LLDP-MED, Private VLAN, protected ports, WRR, Auto VoIP
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
- 44 cm x 20.4 cm x 4.3 cm
- 2.87 kg
- Localisation
- Latin America, North America, Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 16K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SSL, TLS
- Authentication Method
- RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
- Processor
- X ARM Cortex-A9: 600 MHz
- RAM
- 512 MB
- Flash Memory
- 264 MB
- Status Indicators
- Power, fan, link/activity/speed
- 12 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x USB Type A management
- Power Device
- Internal power supply
- 75.3 watt
- Included Accessories
- Foot pad set
- Rack Mounting Kit
- Included
- MTBF
- 938,178 hours
- CISPR 22 Class A, cUL, EN 60950, UL 1950, EN55024, CSA 22.2 No. 950, CB, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55022 Class A, FCC CFR47 Part 15 B Class A, IEC 950, ANSI C63.4-2014, ICES-003:2016 issue 6 Class A, AS/NZS CISPR22:2009+A1:2010 Class A, IEC60950-1:2005, Second edition + A1:2009 + A2:2013, AN/NZS 60950.1:2015, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- Software Included
- Drivers & Utilities
- 44 cm
- 20.4 cm
- 4.3 cm
- 2.87 kg
- 0 °C
- 50 °C
- 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
