Typical campus, warehouse or large building IP telephony, Wireless or Video-Surveillance deployments require flexible and affordable Fiber aggregation.
This 12-port Fiber platform with 12 combo Gigabit ports, provide PoE+ as well – whenever and wherever you want – even far from the MDF or typical wiring closet.
Because PoE deployments are always restrained by 100-meter copper limitation, such low-port count Fiber solution will simplify architectures and even power local PoE+ devices.
High-speed, Layer 2 managed gigabit switching
NETGEAR delivers wires-peed gigabit performance and a full set of Layer 2 management features with unsurpassed affordability. This high-speed switch delivers maximum throughput where you need it - to high-performance workgroups at the edge of the network, or as a backbone for 10/100 switches and gigabit servers in demanding small networks. The non-blocking design offers full gigabit throughput simultaneously to all 12 10/100/1000 ports to ensure reliable performance. Layer 2 management functionality delivers reliability, control, and availability. -
Powerful
A full 12 10/100/1000 ports and a non-blocking design provide wire speed throughput and maximum bandwidth for the most demanding network environments. The 12 combination ports of Gigabit Ethernet interfaces provide the flexibility to deploy fiber or copper connectivity within your network environment. Small Form-factor Pluggable (SFP) modules deliver 1000Base-LX optics. The Layer 2 management features optimize bandwidth throughout the network - delivering gigabit performance to systems, applications, and services. Take advantage of forwarding rates up to 17.8 million pps, and a switching capacity of 24 Gbps. -
Easy to use
Move up to gigabit power in minutes. Use the GSM7212 as a managed switch out of the box - just Plug and Play! All ports are auto-negotiating and support Auto Uplink technology. Management features are simple to set up and use, with a browser interface for easy configuration. Comprehensive remote administration capabilities reduce the need for on-site administration. Easy to troubleshoot - built-in testing capability locates cable related network problems. -
Manageable
Meet your management needs with SNMP (v1, v2c and v3), RMON, Command-Line Interface (CLI) and a complete web-based GUI. Advanced features include up to 256 VLANs, DiffServ traffic prioritization and 802.1p (QoS) for Voice over IP services (VoIP), broadcast storm protection, RADIUS, 802.1x, port trunking, port mirroring, rapid spanning tree, and link aggregation. Full Layer 2 implementation allows you to configure your network for maximum performance, reliability, and availability.
- NETGEAR M4100-12GF - switch - 12 ports - Managed - rack-mountable
- Switch - 12 ports - L2+ - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 12 x combo Gigabit SFP + 4 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 24 Gbps , Throughput: 17.8 Mpps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
- VLAN support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, PoE+, IPv4 support, Link Aggregation Control Protocol (LACP), DHCP client
- IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
- 44 cm x 20.5 cm x 4.3 cm
- 3.7 kg
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- 8K entries
- Max Units In A Stack
- 8
- Routing Protocol
- Static IP routing
- Authentication Method
- RADIUS, TACACS+
- 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB , 12 x SFP (mini-GBIC) , 12 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- 38.5 Watt
- MTBF
- 239,032 hours
- 44 cm
- 20.5 cm
- 4.3 cm
- 3.7 kg
