Talk, play and browse longer than ever with the new mophie powerstation universal battery. This 6,000mAh universal battery is packed with more power then ever. Get more than two additional charges on your smartphone or keep your tablet charged longer for more reading. Two USB ports let you charge multiple devices. The slim design and premium aluminum finish make this pocket-sized model easy to carry.
mophie products go through rigorous testing. Each battery is tested three times to ensure peak performance and safe operation. This is the reason why mophie is the #1 and most trusted brand in portable power.
- mophie powerstation power bank - USB
- Product Type
- Power bank
- 6.92 cm x 11.9 cm x 1.29 cm
- 158.8 g
- Space grey
- Output Connector Type
- Total 2: USB - on cable: Micro-USB
- Max Electric Current
- 2.1 A
- Battery
- 6000 mAh
- Cables
- Micro-USB cable
- 2-year warranty
- Product Type
- Power bank
- 6.92 cm
- 11.9 cm
- 1.29 cm
- 158.8 g
- Enclosure Colour
- Space grey
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Output connectors
- Total 2: 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 2.1 A
- Capacity
- 6000 mAh
- LED power meter
- Material
- Aluminium
- Cables Included
- Micro-USB cable
- Limited warranty - 2 years
