CONTROL EVERYTHING. LIKE MAGIC.
Harmony Elite unifies control of your expanding universe of home entertainment and smart home devices into one powerful yet effortless experience. Sleekly designed and featuring a color touchscreen with motion-sensing backlit keys, and one-touch automation, Harmony Elite makes universal home control intuitively magical. Leave the chaos of multiple apps and remotes behind, and let peace reign supreme.
WORKS WITH YOUR ENTIRE UNIVERSE
Harmony Elite works with over 270,000 entertainment and smart home devices so you can enjoy single-touch control with your favorite brands, right out of the box. From your TV, cable and gaming console, to your AV receiver and Roku® media player -- all the way to your smart lights, locks, thermostats, even your Alexa -- Harmony Elite proudly works with just about everything.
UNLIMITED ACTIVITIES
Lower the blinds, dim the lights, fire-up the TV for movie night -- all with a tap of the finger. With Harmony Activities you can enjoy single-touch automation to trigger limitless experiences. Harmony automatically suggests everyday Activities or you can have fun creating as many as you can dream up. Time for bed? Tap "Good Night" to lock the door and turn out the lights, then fall into a deep and tranquil sleep.
HARMONY ELITE AT-A-GLANCE
ONE-TOUCH ACTIONS
Switch to your favorite channels and between gaming, Netflix®, Apple TV®, and virtually any device.
CUSTOM ACTIVITIES
Create unlimited one-touch or time-triggered activities that group devices into custom experiences.
UNIVERSAL CONTROL
Combine up to 15 remotes and countless apps into one elegant, easy-to-use, universal controller.
REMOTE CONTROL
Set recordings, turn on the lights, or activate any of your devices while you're not home.
EASY SET-UP
Download the Harmony App. Auto-scan for devices. Create custom Activities and Favorites.
ALEXA FOR VOICE CONTROL
Use Amazon Alexa to turn on your TV, select favorite channels or trigger Harmony Activities.
HARMONY APP
Turn your smartphone or tablet into a universal remote (iOS® /Android™ only). Change channels and volume, set up to 50 channel favorites, or trigger multi-device Activities, even when you're away from home.
HARMONY HUB
Harmony Hub centralizes command of all your devices by controlling them with IR, Wi-Fi or Bluetooth® wireless signals. You can hide away the cables and receivers and control everything from behind closed cabinets and doors.
What's in the box?
- Harmony Elite remote (with rechargeable battery)
- Harmony Hub
- 2 IR mini-blasters
- Charging station
- USB cable
- 2 AC adapters
- User documentation
Harmony Elite unifies control of your expanding universe of home entertainment and smart home devices into one powerful yet effortless experience. Sleekly designed and featuring a color touchscreen with motion-sensing backlit keys, and one-touch automation, Harmony Elite makes universal home control intuitively magical. Leave the chaos of multiple apps and remotes behind, and let peace reign supreme -
Harmony Elite works with over 270,000 entertainment and smart home devices so you can enjoy single-touch control with your favorite brands, right out of the box. From your TV, cable and gaming console, to your AV receiver and Roku media player-all the way to your smart lights, locks, thermostats, even your Alexa-Harmony Elite proudly works with just about everything -
Unlimited Activities
Lower the blinds, dim the lights, fire-up the TV for movie night-all with a tap of the finger. With Harmony Activities you can enjoy single-touch automation to trigger limitless experiences. Harmony automatically suggests everyday Activities or you can have fun creating as many as you can dream up. Time for bed? Tap 'Good Night' to lock the door and turn out the lights, then fall into a deep and tranquil sleep
- Logitech Harmony Elite universal remote control
- Universal remote control
- 5.4 cm x 2.9 cm x 19.2 cm
- 164 g
- Connectivity Technology
- Infrared
- Supported Device Qty
- 270000
- Supported Devices
- Home control
- Input Device
- Touch screen
- Wireless Technology
- IEEE 802.11b/g/n, Bluetooth
- Display
- LCD 2.4"
- Battery
- Rechargeable
- 2-year warranty
- 5.4 cm
- 2.9 cm
- 19.2 cm
- 164 g
- Infrared
- 270000
- Supported Devices
- Home control
- Input Device
- Touch screen
- Back-lit buttons, vibration feedback
Display
- Display
- LCD 2.4"
- Colour Display
- Operating System
- MS Windows 7, Windows 8, Apple Mac OS X 10.7 or later, Windows 10, Android 4.2 or later, iOS 8.0 or later
- Included Accessories
- USB cable, remote control charging stand, 2 AC power adapters, 2 IR Blasters, Harmony Hub
- Battery
- Rechargeable
- Limited warranty - 2 years
