Logitech Crayon- Intense Sorbet
Quicklinx: GYTSWS00 Mfr#: 914-000046
10 In Stock
£52.59 ex VAT
£63.10 inc VAT
Let the fun begin! Logitech Crayon is a versatile digital pencil that unleashes your creativity.
  • Precisely on point. No delays
    Know how to use a pencil? Then you know how to use Logitech Crayon. With zero perceptible lag time and precision down to the pixel, just write and draw naturally without fear of missing a single line or detail
  • Palm rejection technology
    Go right ahead and rest your palm on the screen while you write - iPad supports palm rejection for natural hand placement while using Logitech Crayon. Now students can stop worrying about their hands and focus on the task at hand instead
  • The perfect line every time
    Need a thicker or thinner line? Just tilt. Logitech Crayon has a smart tip which dynamically adjusts line weight depending on the angle you place it down - just like a regular pencil
  • Always ready to go
    Just press the on button and start writing or drawing on iPad right away - it's that easy. Logitech Crayon connects to iPad instantly with no complex device pairing or other delays
  • Unleash the power of educational apps
    Logitech Crayon works with a wide variety of educational apps that support Apple Pencil input. So whether students need to take notes in class, mark up a PDF, or sketch diagrams for a science lab, Logitech Crayon is the perfect tool for the job. And the list of indispensable classroom apps is growing bigger every day
  • Shaped to stay put
    The unique design of Logitech Crayon isn't just for show. The flat shape stays exactly where you leave it and prevents it from rolling off desks or getting lost underneath shelves
  • Kid-friendly design
    Curious kids love to pick, poke, and prod anything they can get their hands on so we made key parts of Logitech Crayon pry-resistant and replaceable. The smart tip of Logitech Crayon can't be removed by prying fingers - it requires a special tool. While the rubber cap on the other end is tethered to Logitech Crayon to avoid being misplaced
  • Batteries that last
    Use Logitech Crayon throughout the school day. It can last up to 7.5 hours on a single charge and a smart power management system automatically turns Crayon off after 30 minutes idle time. If a student forgets to charge before class, no need to panic - the charging boost provides 30 minutes of writing time in just 90 seconds
  • The perfect combo
    Logitech Crayon is designed to fit snugly into a holder on the Rugged Combo 2 case for iPad. This way iPad and Logitech Crayon are always kept securely together. So no matter if a student prefers to write or type, they've got the right tool at their fingertips
Logitech Crayon - digital pen - intense sorbet
Digital pen
Wireless
Intense sorbet
1.2 cm x 0.8 cm x 16.3 cm
20 g
Rechargeable battery, 1.2 m drop protection, automatic power off, charging LED Indicator, on/off power switch, tilt sensitive, Palm Rejection Technology
Apple 10.2-inch iPad; 10.5-inch iPad Air (3rd generation); 10.9-inch iPad Air (4th generation, 5th generation); 11-inch iPad Pro; 12.9-inch iPad Pro (3th generation, 4th generation, 5th generation); 9.7-inch iPad (6th generation); iPad mini (6th generation); iPad mini 5 (5th generation)
Digital pen
1.2 cm
0.8 cm
16.3 cm
20 g
Product Material
Aluminium, silicone rubber, PC/ABS
Intense sorbet
Input Device
Wireless
1 x Lightning - Apple Lightning
Lithium polymer
Run Time (Up To)
7 hour(s)
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.9-inch iPad Air (4th generation, 5th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation) , Apple 9.7-inch iPad (6th generation) , Apple iPad mini (6th generation) , Apple iPad mini 5 (5th generation)
Brand: Logitech
