Logitech Spotlight Presentation Remote - Gold
Quicklinx: D9S1WS00 Mfr#: 910-004862
£72.13 ex VAT
£86.55 inc VAT
Spotlight and its companion app work together to deliver a deep range of intelligent and customizable features. You'll step confidently onto stage, and right into your zone.
  • LONG OPERATING RANGE
    Move and present freely from as far as 30 m away  May vary based on environmental and computing conditions.
  • BROAD COMPATIBILITY
    Use Spotlight on Windows and macOS platforms; Powerpoint , Keynote , Acrobat , Google Slide and Prezi presentations; as well as Zoom , Microsoft Teams , and Blue Jeans video conferencing apps
  • TWO WAYS TO CONNECT
    Plug-and-play Spotlight instantly on any compatible computer via USB receiver, or connect with Bluetooth low energy wireless technology. Spotlight also keeps your computer connected and awake while you present
  • FAST RECHARGING
    Use the included USB-C charging cable and get 3 hours of presenting after a 1-minute charge. Spotlight fully charges in as little as 60 minutes. The device will vibrate and the battery indicator glows red when it's time to recharge
Logitech Spotlight presentation remote control - gold
Presentation remote control
Enclosure Colour
Gold
2.81 cm x 1.21 cm x 13.13 cm
49.2 g
Supported Devices
Notebook, personal computer
Wireless Technology
Bluetooth, 2.4 GHz
Buttons Qty
3 buttons
Max Operating Distance
30 m
Rechargeable - lithium polymer
2.81 cm
1.21 cm
13.13 cm
49.2 g
Enclosure Colour
Gold
Wireless Technology
Bluetooth, 2.4 GHz
Supported Devices
Buttons Qty
3 buttons
30 m
Gyroscopic motion-sensing technology, power on/off
Connector Type
1 x USB
Operating System
MS Windows 7 or later, Apple Mac OS X 10.10 or later
Carrying pouch, USB wireless receiver, mini-USB charging cable
85 mAh
Run Time (Up To)
3 months
Recharge Time
1 hour
Brand: Logitech
