Logitech Spotlight Plus Presentation Remote Control
Quicklinx: CS6BWS00 Mfr#: 910-005166
Key Features:
- Brushed aluminium build
- Three-button remote
- Companion Windows and Mac software
- Haptic feedback
- USB-C charging
- Up to 3-months battery life
- Bluetooth with 30m wireless range
The Logitech Spotlight Presentation Remote gives you a new level of control over your presentations. Just install the Logitech Presentation app (available from Logitech) and then use the remote to manage your time, set vibration alerts, toggle pointer mode and customise actions within a user-friendly interface.
With Spotlight you can take a giant step beyond traditional laser pointing. This advanced system lets you precisely highlight or magnify areas of focus in pixel-perfect detail. It's clearly visible to both the audience in the room and everyone watching via video conference.
Small Device. Big Game.
Spotlight and its companion app work together to deliver a deep range of intelligent and customizable features. You'll step confidently onto stage, and right into your zone.
Intuitive Slide Navigation
Enjoy focus and instant familiarity with Spotlight's intuitive three-button interface.
- Pointer - Highlight, magnify, and control the on-screen cursor
- Next - Navigate forward, and control custom functions like gesture scrolling
- Back - Navigate backward, and control custom functions like gesture scrolling
Long Operating Range
Move and present freely from as far as 30 meters (100ft).
Universal Compatibility
Use Spotlight on Windows® and Mac platforms, and on Powerpoint®, Keynote®, PDF™, Google™ Slide and Prezi™ presentations.
Dual Connectivity
Plug-and-play Spotlight instantly on any compatible computer via USB receiver, or connect with low energy Bluetooth® Smart. Spotlight also keeps your computer connected and awake while you present.
  • SPOTLIGHT AND MAGNIFY ON SCREEN
    Take your company's next business presentation beyond traditional laser pointing. Spotlight Plus advanced pointer system lets you precisely highlight or magnify areas of focus, all with pixel-perfect detail. The selected area of focus is clearly visible to both the meeting room audience as well as business groups via video conference. Set the pointer mode with the easy-to-use Logitech Presentation App
  • MOUSE-LIKE CURSOR CONTROL
    The on-screen cursor can be used to play and pause videos, open links, show proprietary corporate content, and enjoy a range of other rich content interaction. No need to break the flow of a business presentation or go near a mouse or laptop. With Spotlight Plus, both the presentation and the company comes shining through
  • LOGITECH PRESENTATION APP
    Pair Spotlight Plus with its powerful app to set time alerts, toggle pointer mode, and customize actions. Configure the back button to go to a blank screen, or to activate gesture-commanded volume control, scrolling, and more. The software can be installed remotely and silently for multiple users. Download the software in .exe format and use deployment tools such as SCCM to install it remotely. Specific command lines allow for silent installation and to disable automatic updates. Learn more in the software installation guide for macOS Windows
  • SMART TIME MANAGEMENT
    Spotlight Plus quietly reminds the speaker when it's time to wrap up. The presentation remote vibrates five minutes before the end of a presentation and again when time is fully up. Speakers can eliminate distractions and awkward interruptions, track presenting time, and customize vibration alerts in the Logitech Presentation App.s 1
  • DUAL CONNECTIVITY
    Sleek, portable, and wireless, Spotlight Plus travels from home office to headquarters to center stage without a glitch. Connect to a computer via USB receiver or low energy Bluetooth . Switch seamlessly between the two by plugging or unplugging the receiver. A discreet and convenient dock built into the base of the actual remote stores the USB receiver when not in use
  • UNIVERSAL COMPATIBILITY
    Spotlight Plus is optimized to work with Windows , Mac OS and all leading presentation software including PowerPoint , Keynote , Adobe PDF, Google Slides , and Prezi
  • 30-METER OPERATING RANGE
    Move and present freely from as far as 30 meters (100 ft) so you can own even the largest rooms. Range may vary based on environmental and computing conditions
  • QUICK CHARGING
    Quick charge in one minute for three hours of use - and use Spotlight Plus for three months on a full charge. When it's time to recharge, Spotlight's battery indicator light glows red. Use the USB-C charging cable to top up the power. Charging time may vary based on environmental and computing conditions
  • Free 6-month Prezi Business trial subscription
    Prezi offers a more visual, collaborative, data-driven and conversational way to present. It combines all the benefits that make your presentations stand out, and includes new business productivity tools such as easy to customize designer templates, smooth HD rendering, secure remote presenting, and highly-anticipated features like live analytics, and cloud-based collaboration
Logitech Spotlight Plus presentation remote control - slate
Presentation remote control
Enclosure Colour
Slate
2.81 cm x 1.21 cm x 13.13 cm
49.2 g
Supported Devices
Notebook, personal computer
Wireless Technology
Bluetooth, 2.4 GHz
Buttons Qty
3 buttons
Max Operating Distance
30 m
Rechargeable - lithium polymer
3-year warranty
2.81 cm
1.21 cm
13.13 cm
49.2 g
Enclosure Colour
Slate
Wireless Technology
Bluetooth, 2.4 GHz
Supported Devices
Buttons Qty
3 buttons
30 m
Gyroscopic motion-sensing technology, power on/off
Connector Type
1 x USB
Operating System
MS Windows 7 or later, Apple Mac OS X 10.10 or later
Carrying pouch, USB wireless receiver, mini-USB charging cable
85 mAh
Run Time (Up To)
3 months
Recharge Time
1 hour
Limited warranty - 3 years
