Logitech Harmony Companion - Universal Remote Control
Quicklinx: CQ22WS00 Mfr#: 915-000240
CONTROL IT ALL WITH EASE
Harmony Companion gives you convenient control over your home entertainment and smart home devices. Its streamlined button layout and full number pad make it a breeze to flip between content and devices. Plus, with the Harmony App, you can program your favorite channels, create multi-device Activities, and enjoy control when you're away from home. Chaos. Meet Harmony Companion.
WORKS WITH YOUR ENTIRE UNIVERSE
Harmony Companion works with over 270,000 entertainment and smart home devices so you can enjoy single-touch control with your favorite brands, right out of the box. From your TV, cable and gaming console, to your AV receiver and Roku® media player -- all the way to your smart lights, locks, thermostats, and even your Alexa -- Harmony Companion proudly works with just about everything.
UNLIMITED ACTIVITIES
Lower the blinds, dim the lights, fire-up the TV for movie night -- all with a tap of the finger. With Harmony Activities you can enjoy single-touch automation to trigger limitless experiences. Harmony automatically suggests everyday Activities or you can have fun creating as many as you can dream up. Time for bed? Tap "Good Night" to lock the door and turn out the lights, then fall into a deep and tranquil sleep.
HARMONY COMPANION AT-A-GLANCE
ONE-TOUCH ACTIONS
Switch to your favorite channels and between gaming, Netflix®, Apple TV®, and virtually any device.
CUSTOM ACTIVITIES
Create unlimited one-touch or time-triggered Activities that group devices into custom experiences.
UNIVERSAL CONTROL
Combine up to 8 remotes and countless apps into one elegant, easy-to-use, universal controller.
REMOTE CONTROL
Set recordings, turn on the lights, or activate any of your devices while you're not home.
EASY SET-UP
Download the Harmony App. Auto-scan for devices. Create custom Activities and Favorites.
ALEXA FOR VOICE CONTROL
Use Amazon Alexa to turn on your TV, select favorite channels or trigger Harmony Activities.
HARMONY APP
Turn your smartphone or tablet into a universal remote (iOS® /Android™ only). Change channels and volume, set up to 50 channel favorites, or trigger multi-device Activities, even when you're away from home.
HARMONY HUB
Harmony Hub centralizes command of all your devices by controlling them with IR, Wi-Fi or Bluetooth® wireless signals. You can hide away the cables and receivers and control everything from behind closed cabinets and doors.
What's in the box?
  • Harmony Companion remote (with battery)
  • Harmony Hub
  • IR mini-blaster
  • USB cable
  • AC adapter
  • User documentation
  • CONTROL IT ALL WITH EASE
  • WORKS WITH YOUR ENTIRE UNIVERSE
    Harmony Companion works with over 270,000 entertainment and smart home devices so you can enjoy single-touch control with your favorite brands, right out of the box. From your TV, cable and gaming console, to your AV receiver and Roku media player-all the way to your smart lights, locks, thermostats, and even your Alexa-Harmony Companion proudly works with just about everything
  • UNLIMITED ACTIVITIES
    Lower the blinds, dim the lights, fire-up the TV for movie night-all with a tap of the finger. With Harmony Activities you can enjoy single-touch automation to trigger limitless experiences. Harmony automatically suggests everyday Activities or you can have fun creating as many as you can dream up. Time for bed? Tap "Good Night" to lock the door and turn out the lights, then fall into a deep and tranquil sleep
Logitech Harmony Companion universal remote control
Universal remote control
5.41 cm x 2.06 cm x 18.41 cm
119 g
Infrared
Supported Device Qty
270000
Supported Devices
Home control, Game console
Wireless Technology
IEEE 802.11b/g/n, Bluetooth
5.41 cm
2.06 cm
18.41 cm
119 g
Infrared
Wireless Technology
270000
Supported Devices
Operating System
MS Windows 7, MS Windows Vista, Windows 8, Apple Mac OS X 10.6 or later, Windows 10, Android 4.2 or later, iOS 8.0 or later
AC power adaptor, USB cable, Harmony Hub, IR Blaster
