Peerless-AV Universal Flat Wall Mount for 37" to 75" Displays
Quicklinx: 7B39WS00 Mfr#: PF650
Type: Mounting kit
35 In Stock
£45.27 ex VAT
£54.32 inc VAT
Easily install medium to large displays with this simple, intuitive mounting solution. Cables are easily managed behind the display with large access ports in the wall plate. Effortlessly achieve the desired display position with smooth sliding along the mount's horizontal wall plate rails.
  • Durable design
    Crafted from cold-rolled steel, this mounting kit offers a robust solution for securing your flat panel display. Its scratch-resistant finish ensures the mount maintains its aesthetic appeal over time, making it a reliable choice for both home and office settings.
  • Versatile compatibility
    Designed to support a wide range of display sizes from 39 inches to 75 inches (94 to 190.5 cm), the Peerless PARAMOUNT Universal Flat Wall Mount is ideal for a variety of viewing environments. The inclusion of both bracket adapter and wall plate components provides flexibility for mounting in different spaces.
  • Secure installation
    With a maximum load weight of 68 kg and accommodating mounting patterns up to 742 mm horizontally and 405 mm vertically, this mount ensures a safe and stable setup for your flat panel, giving you peace of mind.
Peerless PARAMOUNT Universal Flat Wall Mount PF650 mounting kit - for flat panel - gloss black
Mounting kit
Mounting Components
Wall plate, bracket adapter
80.8 cm x 4 cm x 45.7 cm
Recommended Use
Flat panel
Recommended Display Size
39"-75"
Max Mounting Pattern Size
742 x 405 mm
Max Load Weight
68 kg
Material
Cold-rolled steel
Gloss black
5-year warranty
80.8 cm
4 cm
45.7 cm
Material
Cold-rolled steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
742 x 405 mm
39"-75"
Max Load Weight
68 kg
Scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
