Logitech Harmony 900 controls your home-entertainment devices - even when they're out of sight (up to 100 feet away). When it's show time at your house, you won't see a jumble of remotes. You won't see a list of instructions. With RF technology, you won't even need to aim your remote or see your components or cables.
It's easy to extend your reach and turn RF signals into IR commands your devices can understand. Just place the simple-to-install IR blaster and mini blasters near the equipment you want to control.
No more complicated lists of what to turn on or which button to select. Everyone can select what they want to do - such as "Watch TV" - and your Harmony remote does the rest.
You get easy, one-touch access to your entertainment activities - such as watching a DVD, watching TV, listening to music - as well as your favorite channels.
Your rechargeable remote can go a week between charges. Just set it in the base station and it charges up. You won't be looking for batteries when you want to be watching TV.
Wireless RF connection
There's no need to aim your remote, and you can even control devices that you keep behind closed cabinet doors and walls (up to 100 feet away). -
Easy-to-install RF system
It's easy to extend your reach and turn RF signals into IR commands your devices can understand. Just place the simple-to-install IR blaster and mini blasters near the equipment you want to control. -
Replaces up to 15 remotes
Reduce the clutter and complexity of your living room. -
One touch to your entertainment
No more complicated lists of what to turn on or which button to select. Everyone can select what they want to do - such as "Watch TV" - and your Harmony remote does the rest. -
Full-color touch screen
You get easy, one-touch access to your entertainment activities - such as watching a DVD, watching TV, listening to music - as well as your favorite channels. -
Sculpted, backlit buttons in a smart layout
You'll find the right channel - even in the dark. -
Ergonomic design
Fits comfortably in your hand. -
Charged and ready
Your rechargeable remote can go a week between charges. Just set it in the base station and it charges up. You won't be looking for batteries when you want to be watching TV. -
Online setup
You connect your Harmony remote to your computer, select the equipment you have and your Harmony gets set up. There's no trial and error, or looking up and punching codes into your remote to get it working. -
Live answers to your questions
If you hit a snag, live customer support is ready to help. -
Constantly updated A/V control database
How can you be sure it will control what you have? With more than 5,000 brands and 225,000 devices supported, you know Logitech has got you covered. And with more added every day, what you get tomorrow will work too.
- Logitech Harmony 900 universal remote control
- Universal remote control
- Connectivity Technology
- Infrared
- Supported Device Qty
- 15
- Input Device
- Touch screen
- Max Operating Distance
- 30.5 m
- Display
- LCD
- Battery
- 1 x remote control unit battery rechargeable - Lithium Ion
- 1-year warranty
- Infrared
- 15
- Input Device
- Touch screen
- 30.5 m
- Back-lit buttons
Display
- Display
- LCD
- Colour Display
- Connector Type
- 1 x USB
- Operating System
- MS Windows XP, Apple MacOS X 10.3 or later, MS Windows 7
- Cables Included
- 1 x USB cable - external
- Included Accessories
- AC power adaptor, USB cable, remote control charging stand
- Battery
- Included Qty
- 1
- Limited warranty - 1 year
