Harmony Ultimate Hub gives you control of your home entertainment devices from the smartphone you already own. Anyone in the house can download the free Harmony App to turn their smartphone into a personal universal remote, including 50 favorite channel icons and one-touch control.
Harmony Ultimate Hub turns Wi-Fi signals from your smartphone into IR and Bluetooth commands your devices can understand. Access Internet services like Netflix and Hulu on your PS3, Wii or Xbox 360.
Harmony Ultimate Hub also allows you to control home theater devices located inside cabinets or behind walls. You don't have to point your mobile phone or remote at your devices anymore. You don't even have to be in the same room.
Easy mobile setup.
Turn your iPhone or Android smartphone into a universal remote
Harmony Ultimate Hub gives you control of your home entertainment devices from the smartphone you already own. Anyone in the house can download the free Harmony App to turn their smartphone into a personal universal remote, including 50 favorite channel icons and one-touch control. After initial online setup. Channel availability subject to your local service provider -
Swipe and tap to control
Swipe or tap your thumb across your smartphone screen to adjust the volume, change the channel, fast-forward, rewind, pause, play and skip forward or back -
A smartphone app that simply works
Consolidate eight remote controls into one simple mobile app. Harmony is compatible with over 225,000 home theater devices. And unique to Harmony is our patented Smart State technology, which remembers your devices' power and input settings and automatically adjusts them based on what you want to do -
Game console control
Harmony Ultimate Hub turns Wi-Fi signals from your smartphone into IR and Bluetooth commands your devices can understand. Access internet services like Netflix and Hulu on your PS3, Wii or Xbox 360 . Netflix is available in certain countries. Unlimited streaming membership required. More information at www.netflix.com . Hulu is available in certain countries. Membership required -
Control devices behind closed cabinets
Harmony Ultimate Hub also allows you to control home theater devices located inside cabinets or behind walls. You don't have to point your mobile phone or remote at your devices anymore. You don't even have to be in the same room -
Upgrade your Harmony Touch
Harmony Ultimate Hub unlocks the full potential of the Harmony experience by adding RF capabilities to Harmony Touch. Access devices inside closed cabinets, control Bluetooth game consoles and turn your smartphone into a powerful universal remote
- Logitech Harmony Ultimate Hub - Wi-Fi to IR remote control adapter
- Product Type
- Package Content
- AC power adaptor, USB cable, IR transmitter, Wi-Fi to IR remote control adapter
- 2-year warranty
- Product Type
- Package Content
- Connections
- USB
- 2 years
