Linksys LGS116P-UK Unmanaged 16-Port PoE Switch
Quicklinx: 9DXSWS00 Mfr#: LGS116P-UK
The unmanaged switch offers gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference.
PoE support lets you deploy network systems such as wireless access, IP telephony, or video surveillance solutions more quickly and at a lower cost, without having to install separate power supplies for individual devices.
  • Gigabit performance
  • Power where you need it
  • Plug and Play convenience
    Linksys unmanaged switches offer a quick and easy solution to extend your office network with Plug-and-Play installation.
  • Quality of Service (QoS) traffic prioritization
    QoS traffic prioritization gives precedence to particular devices or activities to ensure mission-critical data throughput is maintained regardless of network congestion. Auto-sensing ports automatically optimize speed for each connected device.
Linksys Business LGS116P - switch - 16 ports - unmanaged
Switch - 16 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 8 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
80 W
Performance
Bandwidth: 32 Gbps
MAC Address Table Size
8000 entries
Auto-sensing per device, Quality of Service (QoS), fanless, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
AC 100/230 V (50/60 Hz)
28 cm x 12 cm x 2.5 cm
822 g
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
80 W
Performance
Bandwidth: 32 Gbps
8000 entries
Status Indicators
Port transmission speed, PoE, link/activity
8 x 1000Base-T RJ-45 PoE+ , 8 x 1000Base-T RJ-45
External power adapter
11.31 Watt
Plug and Play, FCC Class A certified
United Kingdom
28 cm
12 cm
2.5 cm
822 g
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
9DXS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
9DXS C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
