Upgrade the data paths of your local wired network to information superhighways with Gigabit switches at the desktop. Accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed.
Robust performance
With a switching capacity of 16 Gbps, the Linksys Business LGS108 ensures efficient traffic management and high-speed connectivity, making it suitable for expanding your network. -
Durable design
Designed to operate in a wide range of environmental conditions, this switch can withstand operating temperatures from 0°C to 50°C and storage temperatures from -40°C to 70°C, ensuring reliability in various settings. -
Easy integration
Featuring 8 RJ-45 connectors that support 1000Base-T for Gigabit Ethernet, the LGS108 allows for simple, hassle-free setup with Plug-and-Play compliance, making network expansion straightforward.
- Linksys Business LGS108 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Bandwidth: 16 Gbps
- MAC Address Table Size
- 4000 entries
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
- Power
- AC 100/230 V (50/60 Hz)
- 16.8 cm x 9 cm x 2.6 cm
- 0.358 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- 4000 entries
- Status Indicators
- Port transmission speed, link/activity
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Power Provided
- 12 V - 0.5 A
- Voltage Required
- 3.355 Watt
- Power Consumption Stand by
- 0.997 Watt
- Plug and Play
- Localisation
- United Kingdom
- 16.8 cm
- 9 cm
- 2.6 cm
- 0.358 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
