Linksys Pro Series wireless AC dual band access points deliver data rates at up to 3x faster than the 802.11n standard. With bandwidth speeds up to 1750 Mbps and wider 80 MHz channels your wireless network can grow without losing speed. Linksys Pro Series wireless-AC dual band access point implements a captive portal to support secure and customized guest Wi-Fi access and can be used at many Wi-Fi hotspots to control wireless access in the area.
Wireless AC speed - up to 1750 Mbps
Linksys Pro Series wireless AC dual band access points deliver data rates at up to 3x faster than the 802.11n standard. With bandwidth speeds up to 1750 Mbps and wider 80 MHz channels your wireless network can grow without losing speed. -
Single point control: cluster
Cluster system management simplifies administration and management efforts with a single point control, simultaneously reducing the costs and complexity of managing multiple wireless access points. -
Captive portal
Linksys Pro Series wireless-AC dual band access point implements a captive portal to support secure and customized guest Wi-Fi access and can be used at many Wi-Fi hotspots to control wireless access in the area. -
3-in-1 access point, WDS & workgroup bridge
It supports deployment as a traditional access point, a wireless distribution system (WDS), or set up as a wireless bridge to extend wireless range. -
Easy to use with PoE+
Integrated 802.3at Power over Ethernet Plus (PoE+) capability eliminates external adapters and facilitate optimal placement. -
Comprehensive network security
Protect and secure your wireless network with business class security features including Wi-Fi Protected Access (WPA/WPA2), 802.1X supplicant authentication, MAC-based ACL, rogue AP detection, SSID-to-VLAN mapping, and more.
- Linksys Pro Series LAPAC1750PRO - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of configured SSIDs: 16 , Virtual interfaces (VLANs): 17
- Power Over Ethernet (PoE) Supported
- PoE+
- 23.8 cm x 24.7 cm x 4.33 cm
- 520 g
- Limited lifetime warranty
- 23.8 cm
- 24.7 cm
- 4.33 cm
- 520 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1750 Mbps
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Status Indicators
- System
- VLAN support, Syslog support, DiffServ support, E-mail alert, MAC address filtering, IPv6 support, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), Multiple SSID support, PoE+, wireless bridge mode, reset button, 3T3R MIMO technology, rogue access point detection, ceiling mountable, security lock slot (cable lock sold separately), 802.1x authentication
- Encryption Algorithm
- WPA, WPA2, WEP
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
- Antenna
- Internal
- 1 x 1000Base-T (PoE+) - RJ-45
- IC, FCC
- PoE+
- Power Device
- External power adapter
- 24 Watt
- Limited warranty - lifetime
- 0 °C
- 35 °C
- 10 - 85% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.71 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
