Linksys VELOP Whole Home Mesh Wi-Fi System WHW0301
Quicklinx: FD8JWS00 Mfr#: WHW0301-UK
  • IEEE 802.11n
  • Bluetooth 4.0
  • Enhanced connectivity
    With dual-band support over 2.4 GHz and 5 GHz frequencies, the Linksys VELOP Whole Home Mesh Wi-Fi System ensures a stable and robust wireless connection throughout your home. The system's ability to automatically switch between bands based on signal strength means every device gets the fastest possible connection, whether you're streaming movies, gaming online, or just browsing the web.
  • Seamless expansion
    Designed to meet the needs of any size home, the Linksys VELOP system features a modular design that allows for easy expansion. Simply add more nodes to extend coverage to every corner of your space, eliminating dead zones and ensuring an uninterrupted connection everywhere.
  • Advanced security
    Keep your network safe with WPA2 encryption that protects your privacy and secures your Wi-Fi against unauthorized access. Combined with parental control features, the Linksys VELOP system offers peace of mind by giving you complete control over your family's online experience.
Linksys VELOP Whole Home Mesh Wi-Fi System WHW0301 - wireless router - Bluetooth, Wi-Fi 5 - desktop
Wireless router
Enclosure Type
Desktop - modular
WAN Ports Qty
1
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Data Transfer Rate
2.2 Gbps
Parental control, wireless bridge mode, reset button, wireless extender mode, MU-MIMO technology, Spot Finder Technology, beamforming technology, Tri-Band
IEEE 802.11ac
7.87 cm x 7.87 cm x 18.5 cm
Android 4.4 (KitKat) or later, Apple iOS 8.0 or higher
United Kingdom
3-year warranty
Wireless router
Enclosure Type
Desktop - modular
Wireless, wired
Frequency Band
Data Transfer Rate
2.2 Gbps
Encryption Algorithm
WPA2
IEEE 802.11ac
716 MHz
RAM
512 MB
Flash Memory
4 GB
Line Properties
Line Coding Format
256 QAM
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
6
External power adapter
Installed Qty
1
1 x network cable
United Kingdom
7.87 cm
7.87 cm
18.5 cm
Limited warranty - 3 years , Technical support
