Linksys VELOP Whole Home Mesh Wi-Fi System WHW0102
Quicklinx: FD8GWS00 Mfr#: WHW0102-UK
  • IEEE 802.11n
Velop Dual-Band Series is a family Whole Home Wi-Fi system of modular nodes that work seamlessly together to create one high-speed, high-range Mesh network for your entire home. Unlike traditional routers with range extenders, it only uses one Wi-Fi network name and password to give you seamless and secure Wi-Fi everywhere. Velop's Intelligent Mesh Wi-Fi functionality, easy set-up and beautiful design make it the perfect upgrade from a traditional router system.
  • Seamless connectivity
    Experience uninterrupted Internet with the Linksys VELOP Whole Home Mesh Wi-Fi System, featuring dual-band technology and seamless roaming for consistent coverage throughout your home.
  • Enhanced performance
    Equipped with MU-MIMO and beamforming technology, this Wi-Fi system ensures high-speed connectivity for multiple devices, optimizing your online experience.
  • Comprehensive coverage
    The system includes two routers, designed to provide extensive Wi-Fi coverage, eliminating dead zones and buffering in every corner of your space.
  • Advanced security
    Keep your network safe with WPA2 encryption, safeguarding your personal information and protecting your devices from unauthorized access.
Linksys VELOP Whole Home Mesh Wi-Fi System WHW0102 - Wi-Fi system - Wi-Fi 5, Bluetooth - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
2 routers
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Frequency Band
2.4 GHz / 5 GHz
Auto-sensing per device, reset button, MU-MIMO technology, beamforming technology, dual band, seamless roaming
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
White
7.87 cm x 7.87 cm x 14 cm
322 g
Android 4.0.3 or later, Apple iOS 8.0 or higher
United Kingdom
Wi-Fi system - mesh - 2-port switch (integrated)
2 routers
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA2
Wi-Fi Rating
AC1300
Mesh Networking
716 MHz
RAM
256 MB
Flash Memory
256 MB
Line Properties
Line Coding Format
256 QAM
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
Installed Qty
2
Enclosure Colour
White
1 x network cable
United Kingdom
7.87 cm
7.87 cm
14 cm
322 g
