Linksys VELOP Whole Home Mesh Wi-Fi System WHW0103
Quicklinx: FD8HWS00 Mfr#: WHW0103-UK
  • IEEE 802.11n
Velop Dual-Band Series is a family Whole Home Wi-Fi system of modular nodes that work seamlessly together to create one high-speed, high-range Mesh network for your entire home. Unlike traditional routers with range extenders, it only uses one Wi-Fi network name and password to give you seamless and secure Wi-Fi everywhere. Velop's Intelligent Mesh Wi-Fi functionality, easy set-up and beautiful design make it the perfect upgrade from a traditional router system.
  • Intelligent mesh technology
    Want a quick path to the Internet? VELOP's intelligent mesh technology works behind the scenes to get you there in no time.
  • Flawlessly designed with you in mind
    Nodes are beautifully designed to fit in any environment. They match any home style.
  • Flexible for any home shape and size
    VELOP nodes are modular and work together to fit in any floor.
Linksys VELOP Whole Home Mesh Wi-Fi System WHW0103 - Wi-Fi system - Wi-Fi 5, Bluetooth - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
3 routers
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Frequency Band
2.4 GHz / 5 GHz
Auto-sensing per device, reset button, MU-MIMO technology, beamforming technology, dual band, seamless roaming
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
White
7.87 cm x 7.87 cm x 14 cm
322 g
Android 4.0.3 or later, Apple iOS 8.0 or higher
United Kingdom
Wi-Fi system - mesh - 2-port switch (integrated)
3 routers
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA2
Wi-Fi Rating
AC1300
Mesh Networking
716 MHz
RAM
256 MB
Flash Memory
256 MB
Line Properties
Line Coding Format
256 QAM
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
Installed Qty
3
Enclosure Colour
White
1 x network cable
United Kingdom
7.87 cm
7.87 cm
14 cm
322 g
