Eliminate dead zones and boost the Wi-Fi signal from your existing router with the Linksys AC1200 BOOST EX Wi-Fi Range Extender (RE6400). The range extender features simple setup options which allow you to quickly determine optimal placement in relation to your router. It works with all Wi-Fi routers, including those from service providers, to deliver uninterrupted video and music streaming, smooth online gaming, and seamless content sharing.
This dual-band extender delivers AC1200 data transfer speeds (N300 + AC867 Mbps) for fast, uninterrupted Wi-Fi that you can enjoy in the far reaches of your home - even outdoors.
Up to N300 + AC867 Mbps speed
Dual band wireless range extender brings speed and reliability, wherever you are. -
Spot Finder technology
Easy to use, mobile-guided range extender setup to extend Wi-Fi range throughout your home. -
Eliminate dead zones and boost Wi-Fi up to 7500 square feet
Easily expand your home Wi-Fi to enjoy uninterrupted streaming, smooth online gaming, and more with the Linksys AC1200 BOOST EX Wi-Fi Range Extender (RE6400). The AC1200 BOOST EX extends your existing Wi-Fi range up to 7500 square feet so you can enjoy a stronger Wi-Fi signal - even outdoors. -
Works with all Wi-Fi routers
The AC1200 BOOST EX is compatible with all Wi-Fi routers, including your existing unit or those from service providers. There's no need to modify your router's settings when installing the extender - you won't have to touch your router at all. -
Strengthens Wi-Fi connection with Dual Bands
Stream movies, play games online, and browse the Web without interruptions thanks to quick data transfer speeds of up to N300 + AC867 Mbps. The range extender features dual bands and can also focus the Wi-Fi signal directly to your connected devices for optimal performance, thanks to Beamforming technology. -
Cross band technology maximizes Wi-Fi
Cross band technology allows information to be obtained on one band and transmitted on the other, resulting in reduced dropped data packets, faster media transfer speeds, and a stronger, more consistent signal throughout your home. -
Wired connection with Gigabit Ethernet port
Connect a wired device such as a gaming console, Blu-ray player, Smart TV, or streaming player to your Wi-Fi network. The extender's Gigabit Ethernet port provides data transfer speeds 10x faster than a Fast Ethernet port.
- Linksys RE6400 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 8.7 cm x 12.1 cm x 6 cm
- 1-year warranty
- 8.7 cm
- 12.1 cm
- 6 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz, 5 GHz
- Wi-Fi Protected Setup (WPS), Cross-Band Technology, Spot Finder Technology, beamforming technology
- Encryption Algorithm
- WPA, WPA2, 128-bit AES
- IEEE 802.11ac
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45
- Limited warranty - 1 year , Technical support - 90 days
