LW922 (GENERATION 1 AND 2) Smart Radiator Valve
Revel in the glow of a warm home. Our smart app allows you to adjust individual room temperatures from wherever you are and intelligent schedules.
Lightwave Smart Radiator Valves allow you to save energy whilst increasing comfort by customising temperatures room by room. Schedule and control heating from anywhere using the Lightwave App. Each valve can be screw-fitted to a radiator in seconds and do not require any plumbing or special tools.
Smart Thermostatic Radiator Valves
Use smart radiator valves to set temperatures and heating schedules and edit them from anywhere using your smartphone.
Zoned heating control
Because Lightwave Radiator Valves can be linked to the Lightwave Link, you can use the Lightwave App to monitor and control the temperature of each room in your house in real time.
Compatibility
Lightwave’s smart thermostatic radiator valves require the link or link plus to operate from the Lightwave App.
'Plug & play’ install
Lightwave is simple and safe to install by yourself. It’s even easier to set up – just ‘plug in and play’ using the Lightwave App.
Product Specifications
Generation 2 device
Requires Link Plus and Link Plus App for operation
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home
- LightwaveRF LW922 - radiator thermostat - white
- Product Type
- Radiator thermostat
- Functions
- Control heating systems
- Power Source
- Battery
- Internet of Things (IoT) Platform
- Apple HomeKit
- Intelligent Assistant
- Google Assistant, Alexa
- Connectivity
- Wireless
- Frequency Band
- 868 MHz
- White
- 2-year warranty
- 6.8 cm x 6 cm x 8.5 cm
- Product Type
- Functions
- Power Source
- Battery
- Connectivity Technology
- Wireless
- Frequency Band
- 868 MHz
- On / off button, remote access
- Platform
- Apple HomeKit
- Compatible Services
- IFTTT
- Form Factor
- AA type
- Required Qty
- 2
- White
- Warranty
- 2-year warranty
- 6.8 cm
- 6 cm
- 8.5 cm
- 100 g
