Netatmo Additional Indoor Module - for Personal Weather Station
Quicklinx: D3X2WS00 Mfr#: NIM01-WW
Type: Weather Station
Compatible With: IFTTT, Nest, Alexa
£49.99 ex VAT
£59.98 inc VAT
This wireless accessory can be placed anywhere in the home. It provides temperature, humidity and CO2 readings for the room it is in, sending you alerts when you need to air out the house, making it healthier. You can connect up to 3 Additional Modules to your Netatmo Weather station.
Works with Netatmo Personal Weather Station.
  • Discover your home environment
    The Weather Station's Indoor Module measures your indoor comfort by providing vital data through its sensors, alerting you when you need to air out your home to bring down its pollution levels.
  • Discover your external environment
    The Weather Station's wireless Outdoor Module gives you real-time weather data that matters: measurements are gathered from its sensors right on your doorstep.
  • A healthier home
    Netatmo spends 80% of time indoors, and yet indoor air is often more polluted than outdoor air. The Netatmo Weather Station measures indoor pollution levels through a CO2 sensor, sending you alerts so you can air out your home when necessary and live in a healthier indoor environment.
  • Analyze past data, observe the present and forecast the future
    The Weather Station App allows you to view your indoor and outdoor weather data (temperature, humidity, barometric pressure, CO2 and noise) in graph form for real-time tracking of your environment. Observe the cycles and forecast variations around you.
Netatmo NIM01-WW - thermo-hygro-CO2 metre
Thermo-hygro-CO2 metre - indoor
Measuring Functions
Temperature, humidity, CO2
4 AAA batteries
Remote Sensor
Wireless - 868 MHz, 915 MHz
4.5 cm x 4.5 cm x 10.5 cm
Measuring Functions
Remote Sensor
Wireless
Frequency Band
868 MHz, 915 MHz
Max Range Indoors
100 m
Weather Measuring
Parameter
Temperature: 0 °C to 50 °C - accuracy: +/- 0.3° , Humidity: 0 % to 100 % - accuracy: +/- 3% , Indoor CO2 level: 0 ppm to 5000 ppm - accuracy: +/- 5%
AAA type
Required Qty
4
4 AAA batteries
4.5 cm
4.5 cm
10.5 cm
Compatible With: Nest
Compatible With: Alexa
Brand: Netatmo
