LightwaveRF Home Thermostat
Quicklinx: DL92WS00 Mfr#: LW921
LW921 (GENERATION 1 AND 2) Home Thermostat
Revel in the glow of a warm home. Our smart app allows you to adjust individual room temperatures from wherever you are and intelligent schedules.
Our smart wireless thermostat enables you to monitor, schedule and control your heating from anywhere via your smartphone. It is designed to work in combination with the Lightwave Boiler Switch.
Wireless Central Heating Thermostat
Control the temperature in your home from anywhere at any time with our smart wireless Home Thermostat and the Lightwave App.
Smart control
Link the wireless Lightwave Home Thermostat with the Lightwave App and you’ll be able to schedule, monitor and control the temperature in your home in real time and from anywhere using your smartphone.
How it works
The Lightwave Home Thermostat is designed to work alongside the Boiler Switch to control and schedule the boiler.
Remote thermostat
The Home Thermostat works with Lightwave Link or the Link Plus and Lightwave App giving you instant or scheduled control of your heating from anywhere.
Product Specifications
Generation 2 device
Requires Link Plus and Link Plus App for operation
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home
LightwaveRF LW921 - thermostat - white
Thermostat
Functions
Control heating systems
Power Source
Internet of Things (IoT) Platform
Apple HomeKit
Intelligent Assistant
Google Assistant, Alexa
Wireless
Frequency Band
868 MHz
White
9.6 cm x 2.2 cm x 9.4 cm
Thermostat
Functions
Power Source
Wireless
Frequency Band
868 MHz
HomeKit technology, remote access
Platform
Apple HomeKit
Compatible Services
IFTTT
Thermostat
Programmable
AA type
Required Qty
2
White
Warranty
9.6 cm
2.2 cm
9.4 cm
125 g
