Simply click, point, scroll or use voice commands to change the channel, search for something new, and more. The LG Magic Remote can also be used to operate your connected devices. Spend less time navigating confusing menus and juggling multiple remotes, and more time enjoying your entertainment.
 - LG Magic Remote Control AN-MR600 remote control
 - Remote control
 - 4.83 cm x 3.37 cm x 18.35 cm
 - 101.7 g
- Connectivity Technology
 - Radio
- Supported Devices
 - LCD TV
- Input Device
 - Scrolling wheel
- Max Operating Distance
 - 10 m
- Battery
 - 2 AA type
- Designed For
 - LG 32LF6300, 40LF6300, 43UF7700, 49UF800, 49UF850, 49UF8500, 55LF6300, 55UF7700, 55UF800, 55UF850, 55UF8500, 55UF860, 55UF950, 55UF9500, 55UG870, 60LF6300, 60UF7700, 60UF850, 60UF8500, 65EF9800, 65LF6300, 65UF7700, 65UF800, 65UF850, 65UF860, 65UF950, 65UG870, 70UF7700, 79UF7700, 79UF860, 79UF9500
 - Remote control
 - 4.83 cm
 - 3.37 cm
 - 18.35 cm
 - 101.7 g
 - Radio
- Supported Devices
 - LCD TV
- Input Device
 - Scrolling wheel
 - 10 m
 - Mouse emulation, voice control, scrolling, gestures
 - 0 °C
 - 60 °C
- Battery
 - 2 AA type
- Designed For
 - LG 32LF6300, 40LF6300, 43LF6300, 43UF7700, 49LF6300, 49UF800V, 49UF8500, 49UF850V, 55EF9500, 55EG9600, 55LF6300, 55UF7700, 55UF800V, 55UF8500, 55UF850V, 55UF860V, 55UF9500, 55UF950V, 55UG870V, 60LF6300, 60UF7700, 60UF8500, 60UF850V, 65EF9500, 65EF9800, 65EG9600, 65LF6300, 65UF7700, 65UF800V, 65UF8500, 65UF850V, 65UF860V, 65UF9500, 65UF950V, 65UG870V, 70UF7700, 79UF7700, 79UF860V, 79UF9500
