The Intel Ethernet 10 Gigabit Converged Network Adapter X520-SR1 enables data center transformation by delivering a reliable, unified 10GbE short range fiber optic connection. The Intel Ethernet Converged Network Adapter X520 provides advanced unified networking capabilities, including support for iSCSI, NFS, and FCoE. The Intel Ethernet Converged Network Adapter X520 facilitates greater network infrastructure consolidation and is the best choice for I/O virtualization. Intel Ethernet - it just works!
Efficient cooling
Designed to operate within a wide temperature range, the Intel Ethernet Converged Network Adapter X520-SR1 ensures reliable performance from 0°C to 55°C. This feature ensures stable operation in various environmental conditions, making it suitable for data centers and high-temperature environments. -
High-speed connectivity
With a data transfer rate of 10 Gbps and support for Ethernet 10GBase-SR, the adapter provides high-speed connectivity for demanding network applications. It's ideal for high-performance computing, data analytics, and server virtualization. -
Advanced networking features
Supporting a range of networking protocols including IEEE standards, VLAN, and Virtual Machine Device Queues (VMDq), the adapter enhances data flow efficiency and security. It's designed to improve network management and support features like Fiber Channel over Ethernet (FCoE). -
Secure and compliant
Meeting multiple compliance standards such as FCC, RoHS, and UL, the Intel Ethernet Converged Network Adapter X520-SR1 adheres to strict regulatory requirements. This ensures a high level of reliability and safety for users. -
Versatile compatibility
The adapter's compatibility with PCI Express 2.0 x8 slots and its low-profile form factor make it a versatile solution for a wide range of PC systems. This flexibility allows for easy integration into existing setups without the need for extensive modifications.
- Intel Ethernet Converged Network Adapter X520-SR1 - network adapter - PCIe 2.0 x8 - 10GBase-SR
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x8
- Ports
- 10GBase-SR
- Cabling Type
- Ethernet 10GBase-SR
- Data Link Protocol
- 1GbE, 10GbE, FCoE
- Data Transfer Rate
- 10 Gbps
- TCP/IP, UDP/IP, IPSec, iSCSI
- Processor
- Intel 82599ES
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3ad (LACP), IEEE 802.1ae, IEEE 802.1as
- System Requirements
- Microsoft Windows 7, Linux 2.6.x, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 SP2, Microsoft Windows Vista SP2, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2003 SP2, Red Hat Enterprise Linux 6, VMware ESXi, Windows 8, Microsoft Windows Server 2012, VMware ESX, Linux 3.x, FreeBSD 9
- Limited lifetime warranty
- Network adapter
- Form Factor
- Ports
- 10GBase-SR
- Connectivity Technology
- Wired
- Cabling Type
- Gigabit Ethernet, 10 Gigabit Ethernet, Fibre Channel over Ethernet (FCoE)
- 10 Gbps
- Remote Management Protocol
- SNMP, RMON
- Status Indicators
- Port transmission speed, link/activity
- Load balancing, VLAN support, VMDq
Processor / Memory
- Processor
- Intel 82599ES
- 1 x 10GBASE-SR - LC multi-mode - x 2
- Compatible Slots
- 1 x PCI Express 2.0 x8
- FCC Class B certified, UL, VCCI, C-Tick, BSMI, RoHS
- Package Type
- Bulk
- OS Required
- Limited warranty - lifetime
- 0 °C
- 55 °C
Intel Ethernet SFP+ Optics – SR | In Stock | £24.94 |
