Now you can maximize system performance and increase end-user productivity for mainstream PCs with the new Intel PRO/1000 GT Desktop Adapter. Today's desktops are weighed down with high-bandwidth applications including voice, data, streaming video, video conferencing, and long-distance storage area networks. The environmentally friendly Intel PRO/1000 GT Desktop Adapter's Gigabit bandwidth makes quick work of these network applications with power to spare. The Intelligent Way to Connect Built on Intel lead-free technology, the Intel PRO/1000 GT Desktop Adapter is the environmentally friendly way to bring Gigabit performance to your desktop at no extra cost. The GT Desktop Adapter contains no lead and conforms to the European Union's Restrictions on the use of Hazardous Substances and Japan's White Goods Recycling Act.
Intel Ethernet- It just works!
Simplify installation and maintenance with Intel Single Driver technology
Intel offers a single driver across all Intel PRO/1000 Desktop and Server Adapters making it easier to administer and upgrade to the latest generation of Intel adapters, simplifying network management and reducing maintenance costs. -
High-performing, auto-negotiating 10/100/1000 connection
Systems that are currently running at 10 Mbps or 100 Mbps can be upgraded with the Intel PRO/1000 GT Desktop Adapter now, whether Gigabit switching is currently available or not. By integrating an Intel PRO Gigabit Network Connection now, information technology (IT) managers will save time, money and downtime when the network is upgraded later because the Intel PRO/1000 GT Desktop Adapter will automatically detect and run at the higher speed when it becomes available.
- Intel PRO/1000 GT Desktop Adapter - network adapter - PCI / 66 MHz - Gigabit Ethernet
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI / 66 MHz
- PCI Specification Revision
- PCI 2.3
- Bus Voltage
- 5.0 V
- Ports
- Gigabit Ethernet
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- TCP/IP
- Processor
- 1 x Intel 82541PI
- RAM
- 64 KB
- IEEE 802.2, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, WfM 2.0
- System Requirements
- Microsoft DOS, Novell NetWare 4.2, Novell NetWare 5.1, Microsoft Windows 2000 / NT4.0, Linux 2.2.5 or later, Microsoft Windows XP, Microsoft Windows 98 Second Edition / Windows ME, Novell NetWare 6
- Microsoft Certification
- Certified for Windows Vista
- Limited lifetime warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI / 66 MHz
- PCI 2.3
- Bus Voltage
- 5.0 V
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- TCP/IP
- Remote Management Protocol
- SNMP, DMI 2.0
- Flow control, full duplex capability, ACPI support, auto-negotiation, VLAN support, WOL, manageable
Processor / Memory
- Processor
- 1 x Intel 82541PI
- RAM
- 64 KB
- 1 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x PCI / 66 MHz
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Plug and Play, FCC Class B certified, VCCI Class B ITE, BSMI CNS 13438 Class B
- Software Included
- Drivers & Utilities, Intel PROSet
- OS Required
- Limited warranty - lifetime
- 0 °C
- 55 °C
- 0 - 85%
Customer reviews
Write a review for the Intel PRO/1000 GT Desktop Adapter - network adapter here!
Excellent
Reviewed by Anonymous Review Posted 15/02/2006
It is running great and stable with Windows Server 2003. Fast file transfers, with little or no strain on CPU. Overall im very happy, easy to install and no problem so far.
- Overall
- Ease of use
- Value for money
Intel PCI Gigabit NIC
Reviewed by Kevin. Review Posted 14/05/2006
Works great with x86 and x64 Windows (all versions) and Linux.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
