Intel Dual Band Wireless-AC 8265 Desktop Kit Network Adapter
Quicklinx: DF9HWS00 Mfr#: 8265.NGWMG.DTX1
  • IEEE 802.11n
The Intel Dual Band Wireless-AC 8265 adapter supports Bluetooth 4.2 and 2x2 11ac Wi-Fi delivering high speeds including wave 2 features such as downlink MU-MIMO providing increase in user speeds in dense deployments, supporting fast downloads and long battery life. Intel Dual Band Wireless-AC 8265 dramatically reshapes your connected experience at home, work or on the go.
  • Enhanced connectivity
    With support for Bluetooth 4.2 and Wi-Fi across both 2.4 GHz and 5 GHz bands, the Intel Dual Band Wireless-AC 8265 network adapter ensures a versatile and stable connection for all your wireless needs.
  • Robust security
    Featuring a wide range of encryption algorithms including AES-CCMP, WPA, and WPA2, this network adapter provides a secure connection, protecting your data from unauthorized access.
  • High-speed performance
    Achieve data transfer rates of up to 867 Mbps, thanks to dual-stream (2x2) technology and support for IEEE 802.11ac, making it ideal for high-definition video streaming, gaming, and high-speed file transfers.
Intel Dual Band Wireless-AC 8265 - Desktop Kit - network adapter - M.2 Card
Network adapter
Plug-in card
Interface (Bus) Type
M.2 Card
3 cm x 0.24 cm x 2.2 cm
2.6 g
Wi-Fi 5, Bluetooth 4.2
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11w, Bluetooth 4.2
Linux, Microsoft Windows 7 / 8.1 / 10
1-year warranty
Network adapter
Plug-in card
M.2 Card
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
WiDi, dual-stream (2x2), Intel Smart Connect Technology
Aerial
Antenna
External detachable
Antenna Qty
2
Low-profile bracket, full-height bracket
2 x coaxial RF cable
Encryption Algorithm
LEAP, 128-bit WEP, 64-bit WEP, TLS, PEAP, TTLS, WPA, WPA2, AES-CCMP
UL, cUL, CB, IEC 60950-1, FIPS, FISMA
3 cm
0.24 cm
2.2 cm
2.6 g
Limited warranty - 1 year
80 °C
50 - 90% (non-condensing)
