The 802.11 ac, dual-band, 2 x 2 Wi-Fi plus Bluetooth adapter that lets you move at the speed of life with faster speeds, higher capacity, broader coverage, and longer battery life. Combined with 4th generation Intel Core processors and exceptional Intel wireless innovations, the Intel Dual Band Wireless-AC 7260 dramatically reshapes your connected experience at home, work, or on the go.
- Intel Dual Band Wireless-AC 7260 - network adapter
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express Half Mini Card
- 3 cm x 0.24 cm x 2.68 cm
- Data Link Protocol
- 802.11b, 802.11a, 802.11g, 802.11n, 802.11ac, Bluetooth 4.0 LE
- Data Transfer Rate
- 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.3ac, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, Bluetooth 2.1, Bluetooth 3.0, Bluetooth 4.0, IEEE 802.11w
- System Requirements
- Linux, Microsoft Windows 7, Windows 8
- Network adapter
- Form Factor
- Plug-in card
- Connectivity Technology
- Wireless
- 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), Intel Wireless Display (WiDi), Intel Smart Connect Technology
- Encryption Algorithm
- LEAP, 128-bit WEP, 64-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA2
- UL, cUL, CB, IEC 60950-1, FIPS
- OS Required
- 3 cm
- 0.24 cm
- 2.68 cm
- 0 °C
- 80 °C
- 50 - 90% (non-condensing)
