The ProLite XUB2294HSU featuring VA panel technology guarantees accurate and consistent color reproduction with wide viewing angles. Triple input configuration (VGA, HDMI, DisplayPort) and a USB hub assure compatibility with many platforms.
VA matrix
VA panel technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Height-adjustable stand
With a height-adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements.
- iiyama ProLite XU2294HSU-B1 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A+
- Energy Consumption per Year
- 23 kWh
- Power Consumption (On mode)
- 16 W
- USB 2.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Matte
- Matte black
- 48.85 cm x 18.7 cm x 37.6 cm
- 3 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- TUV GS, DDC-2B, PSE Mark, REACH, VCCI Class B, CU, REACH SvHC
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 23 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 85 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese
- Bezel Type
- Flat front
- Ultra Slim Design, HDCP, Eco-Mode, 72% NTSC colour gamut, High Frame Rate Control (Hi-FRC), Advanced Contrast Ratio (ACR), 99% sRGB colour gamut, Flicker Free technology, blue light reduction, i-Style Color, 8-bit gamma
- Matte black
- 48.85 cm x 18.7 cm x 37.6 cm - with stand
- 3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , HDMI (HDCP) , DisplayPort , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , Headphones (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 16 W
- 19 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.26 Watt
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
