iiyama ProLite TF1534MC-B6X 15" 1024x768 8ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ2HWS00 Mfr#: TF1534MC-B6X
The ProLite TF1534MC-B6X 15" multitouch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust and water resistant from the front. For ease of installation in any environment the ProLite TF1534MC-B6X comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and Instore Retail.
  • Capacitive touch technology
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass.
  • Open frame brackets
    This open frame monitor comes equipped with external mounting brackets. It guarantees easy installation and makes it an ideal solution for kiosk integrators and Instore Retail.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Anti-fingerprint coating
    This special nano coating ensures a smoother touch and less resistance in the swipe. It makes the screen less static and susceptible to dirt, dust, fingerprints and it improves the clarity of the content displayed on the screen.
iiyama ProLite TF1534MC-B6X - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Energy Class
Class E
Power Consumption (On mode)
10.8 W
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Contrast Ratio
700:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Black, matte
33.75 cm x 4.45 cm x 26.55 cm
2.7 kg
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, EAC, REACH SvHC
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Brightness w/touchscreen
330 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31.4 - 60 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
HDCP, OSD lock, HID Compliant, scratch-resistant, anti-fingerprint, glove touch mode
Black, matte
2.7 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DisplayPort , VGA , USB , HDMI
Mechanical
VESA Mounting Interface
100 x 100 mm
90% light transmittance
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Mounting Kit
Included
10.8 W
10.8 kWh/1000h
Power Consumption (Typical)
9 Watt
Power Consumption Stand by
2 Watt
Power Consumption (Off Mode)
2 Watt
Included Software
Drivers & Utilities
Linux, Microsoft Windows
Limited warranty - 3 years
