With its Full HD (1920 x 1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2336MSC delivers seamless and accurate touch response. The IPS panel technology guarantees high performance with exceptional color reproduction and wide viewing angles, making it an excellent choice for a vast array of demanding interactive applications. The flexible stand can be positioned at several angles, creating a comfortable and ergonomic user experience.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched. -
OverDrive ON/OFF
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Blue light reducer
As we all know looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows our eyes to feel less tired while working long hours with a computer screen. They achieved it by adjusting the monitor's brightness and color temperature through a new feature called "Blue light reduction"; easily accessible through the monitor's OSD menu.
- iiyama ProLite T2336MSC-B2 - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23" - touchscreen
- Energy Class
- Class F
- Energy Consumption per Year
- 19 kWh
- Touch-screen, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- 7H Hard Coating
- Voltage
- AC 120/230 V (60 Hz)
- Black
- 56.1 cm x 25.4 cm x 37.9 cm
- 6.3 kg
- VCCI, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 19 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 213 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock, blue reduction
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Japanese
- Eco-Mode, Advanced Contrast Ratio (ACR), HID Compliant, blue light reduction
- Black
- 56.1 cm x 25.4 cm x 37.9 cm - with stand
- 6.3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- DVI-D , VGA , HDMI , Audio line-in , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A)
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x SuperSpeed USB cable , 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption Stand by
- 0.7 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 7 / Windows 8
- Dimensions & Weight Details
- With stand - width: 56.1 cm - depth: 25.4 cm - height: 37.9 cm - weight: 6.3 kg , Without stand - width: 56.1 cm - depth: 5.7 cm - height: 33.8 cm
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
