iiyama ProLite T2234AS-B1 21.5" 1920x1080 8ms Touchscreen IPS LED Monitor
Quicklinx: FJ2WWS00 Mfr#: T2234AS-B1
  • Bluetooth 4.0
  • IEEE 802.11n
Connect and go with the ProLite T2234AS-B1, the all-in-one monitor solution for shops, retail or information desks. This 21.5" PCAP 10-point touchscreen with Android allows users to directly connect and operate the monitor from any device. The HDMI output makes it easy to connect a second customer-facing display for dynamic content and advertising.
The robust screen comes with a rugged bezel and an IP65 rating, meaning the monitor is dust and water resistant from the front. Cables can be neatly tied with the special cable cover, so they cannot come loose or move around. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angels, making it a perfect interactive display for instore retail.
  • Android OS
    Thanks to Android OS, you can easily customize the display to your needs by installing applications directly to it.
  • Anti-fingerprint coating
    This special Nano coating ensures a smoother touch and less resistance in the swipe. It makes the screen less static and susceptible to dirt, dust, fingerprints and it improves the clarity of the content displayed on the screen.
iiyama ProLite T2234AS-B1 - kiosk RK3288 1.8 GHz - 2 GB - SSD 16 GB - LED 21.5"
Kiosk - kiosk
1 x Rockchip RK3288 / 1.8 GHz (Quad-Core)
RAM
2 GB LPDDR3 SDRAM
Hard Drive
SSD 16 GB - eMMC
Optical Storage
No optical drive
Monitor
21.5" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
ARM Mali-T760 MP4
Audio Output
Stereo
1GbE, 802.11a, RS-232C, 802.11b/g/n, Bluetooth 4.0
OS Provided
Android 8.1 (Oreo)
51.75 cm x 35.15 cm x 21.9 cm
6.6 kg
Limited warranty - 3 years
Kiosk
Product Form Factor
Kiosk
Built-in Devices
Speaker, capacitive touch screen
Processor / Chipset
CPU
Rockchip RK3288
Clock Speed
1.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
2 GB
LPDDR3 SDRAM
Hard Drive
SSD - eMMC
1 x 16 GB
Optical Storage
No optical drive
Monitor
Monitor Type
LED - IPS
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
21.5"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Pixel Pitch
0.247 mm
Response Time
8 ms
Image Brightness
350 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Cable management cover, HDCP, Projected Capacitive Touch (PCT) technology, Hard Coating (7H)
Graphics Controller
Graphics Processor
ARM Mali-T760 MP4
Audio Output
Sound Output Mode
Stereo
Input Device
Touch-screen
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, RS-232C, IEEE 802.11n, Bluetooth 4.0
2 x USB 2.0 (OTG) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HDMI , 1 x serial
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
Plug and Play, DDC-2B, CCC, cULus, CU, REACH SvHC, IP65 front
Power adapter
25 Watt
Power Consumption Stand by
0.5 Watt
Operating System / Software
OS Provided
Android 8.1 (Oreo)
51.75 cm
35.15 cm
21.9 cm
6.6 kg
