The ProLite T1732MSC-W5AG multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touchscreen with an adjustable stand offering full 90 degree positioning angles.
- iiyama ProLite T1732MSC-W5AG - LED monitor - 17"
- LED-backlit LCD monitor - 17" - touchscreen
- Energy Class
- Class E
- Energy Consumption per Year
- 27 kWh
- Power Consumption (On mode)
- 11.9 W
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Matt white
- 38.7 cm x 20.2 cm x 34.2 cm
- 5.6 kg
- Plug and Play, VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU
- Display Type
- Energy Class
- Class E
- 27 kWh
- Diagonal Size
- 17"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 215 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 31 - 80 KHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Spanish, Japanese, Chinese
- Cable management cover, HDCP, edge-to-edge glass, OSD lock, scratch-resistant, Advanced Frame Rate Control (AFRC), glove touch mode
- Matt white
- 38.7 cm x 20.2 cm x 34.2 cm - with stand
- 5.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA ¦ HDMI ¦ DisplayPort ¦ USB ¦ Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Cable cover
- Security Slot Type
- Kensington security slot
- Input Voltage
- 11.9 W
- Power Consumption SDR (On mode)
- 11.9 kWh/1000h
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Drivers & Utilities
