iiyama ProLite T1531SR-B5 15" 1024x768 8ms HDMI VGA DisplayPort LED Monitor
Quicklinx: DKJFWS00 Mfr#: T1531SR-B5
Iiyama ProLite T1531SR-B5 15" touchscreen LED Monitor - 1024 x 768,TN - 370 cd/m² - 700:1 - 8 ms, HDMI, VGA, DisplayPort, with speakers in matte black
  • Efficient power usage
    With a power consumption of only 16 W during operation and a mere 2 W in standby mode, this monitor is designed for energy efficiency, making it an eco-friendly choice for users concerned about their energy footprint.
  • Versatile connectivity
    Equipped with HDMI, VGA, and DisplayPort interfaces, this monitor offers flexible connectivity options, allowing users to easily connect to a variety of devices without the need for multiple adapters.
  • Enhanced touch technology
    Featuring 5-Wire Resistive Touch Screen Technology, this monitor provides a responsive and accurate touch experience, enabling users to interact with their content more directly and intuitively.
  • Optimal viewing experience
    The LED-backlit LCD monitor boasts a 15-inch display with a 1024 x 768 native resolution, offering clear and vibrant visuals. The tilt adjustment feature allows users to find the perfect viewing angle for comfort and productivity.
iiyama ProLite T1531SR-B5 - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Energy Class
Class E
Energy Consumption per Year
20 kWh
Power Consumption (On mode)
10.6 W
Touch-screen, stylus
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Contrast Ratio
700:1
Response Time
8 ms
Input Connectors
Display Position Adjustments
Tilt
Voltage
Matte black
35.1 cm x 20.1 cm x 30.6 cm
4.8 kg
Plug and Play, VCCI, DDC-2B, CB, IP54, TUV Bauart, CU
3-year warranty
Display Type
Energy Class
Class E
20 kWh
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Brightness w/touchscreen
300 cd/m²
Contrast Ratio
700:1
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 60 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, 5-Wire Resistive Touch Screen Technology
Matte black
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen, stylus - touchscreen
Movement Detection Technology
Resistive
VGA , HDMI , DisplayPort , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 80% light transmittance
1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
10.6 W
10.6 kWh/1000h
Power Consumption (Typical)
16 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
