iiyama ProLite LH5050UHS-B1 50"  3840x2160 LED Digital Signage
Quicklinx: DKJVWS00 Mfr#: LH5050UHS-B1
See the difference with the ProLite LH5050UHS. This is a professional digital signage display with amazing graphics, continuous operating time and landscape/portrait orientation. Featuring a slim bezel, ambient light sensor and an AMVA3 panel for exceptional color and image performance, the LH5050UHS offers businesses a versatile and effective solution to present their message in an innovative and engaging manner.
  • LAN control
    LAN control enables making adjustments in the display OSD menu through your network.
  • AMVA3
    AMVA3 technology offers higher contrast, darker blacks and much better viewing angles. The screen will look good no matter what angle you look at it.
  • DisplayPort/HDMI daisy chain support
    A daisy chain is a wiring scheme in which multiple devices are wired together in sequence or in a ring. It enables a connection of a series of devices using a single connection between each two devices, using DisplayPort/HDMI input and a DisplayPort/HDMI output. The output connects to the next downstream display. This cabling arrangement, with one DisplayPort/HDMI cable between each set of monitors, provides a simple, less cluttered system configuration.
  • Light sensor
    The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light.
iiyama ProLite LH5050UHS-B1 50" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
50"
Commercial Use
Yes - digital signage
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
HDMI, DisplayPort, serial RS-232
AMVA3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
3 ports
Remote control, 4 screws, batteries, mini-PC bracket
Voltage
Energy Class
Class C
140 Watt
Power Consumption (On mode)
156 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
228 kWh
113.25 cm x 7 cm x 65.6 cm
14.3 kg
Energy Class
Class C
140 Watt
156 W
228 kWh
Diagonal Class
50"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Fanless Design
Dimensions
Without stand
113.25 cm
7 cm
65.6 cm
14.3 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
AMVA3
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
Daisy Chain
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
3
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Functionality
Streaming media playback
LAN
Connector Type
3 x component video input , 3 x HDMI input , DisplayPort input , Audio input , RS-232 input , LAN , Infrared input , Daisy chain output , Audio output , 2 x audio output , RS-232 output , USB 3.0 , 2 x USB 2.0
HDMI cable - 1.8 m , DisplayPort cable - 1.8 m
Plug and Play, DDC-2B, CB, TUV Bauart, CU, DisplayPort 1.2
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
131 cm
Depth (Shipping)
22.6 cm
Height (Shipping)
80 cm
Weight (Shipping)
20.6 kg
