The ProLite TF1515MC-B1 (15 inch) uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen. -
Open frame brackets
This open frame monitor comes equipped with external mounting brackets. It guarantees easy installation and makes it an ideal solution for kiosk integrators and Instore Retail. -
IP
The IP code classifies and rates the degree of protection against water intrusion. IP65 means that the monitor is protected to water splashes against the enclosure from any direction. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched. -
Foam seal
A foam seal finish (8mm) around the monitor ensures seamless integration and optimal dust protection.
- iiyama ProLite TF1515MC-B1 15" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 15"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1024 x 768
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15), HDMI, DisplayPort
- Technology
- TN+Film
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 4:3
- TV Tuner
- No tuner
- Speaker System
- Speakers not included
- USB
- Included Accessories
- Remote control, remote control
- Energy Class
- Class A
- 16 Watt
- Power Consumption (On mode)
- 11 W
- Power Consumption Stand by
- 1.2 Watt
- Energy Consumption per Year
- 15 kWh
- Dimensions (WxDxH) - without stand
- 29.1 cm x 4.15 cm x 36.4 cm
- 2.9 kg
- Product Type
- Energy Class
- Class A
- 16 Watt
- 11 W
- 15 kWh
- Diagonal Class
- 15"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- Modes
- Portrait mode, landscape mode, Face-up Mode
- Protection
- Anti-scratch display
- Dimensions
- Without stand
- 29.1 cm
- 4.15 cm
- 36.4 cm
- 2.9 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- TN+Film
- Resolution
- 1024 x 768
- 4:3
- Edge-lit LED
- Coating
- 7H Hard
- Image Contrast Ratio
- 800:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 160 degrees
- Viewing Angle (Vertical)
- 150 degrees
- Touchpoints Qty
- 10
- Response Time
- 8 ms
- Display Menu Language
- English, French, Italian, Spanish, Dutch, Japanese, Chinese
- 3M Projected Capacitive Technology (PCAP)
Stands & Mounts
- Flat Panel Mount Interface
- 100 x 100 mm
Media Player
- USB Port
Remote Control
- Remote control
Audio System
- Speaker System
- Connector Type
- VGA input , DisplayPort input , HDMI , USB , Audio line-out
- Remote control
- Cables Included
- DisplayPort cable , USB cable , HDMI cable
- DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, IP65, CU
- Power Device
- Power supply
- 1.2 Watt
