See the difference with the ProLite professional signage display. Featuring a slim bezel and an IPS LED panel for exceptional color and image performance, it offers businesses an easy and effective solution to successfully help them get their message across to the clients.
Enhanced audio experience
With a total output power of 20 watts and a two-speaker system, this display offers an immersive audio experience for any content. -
Versatile connectivity
Equipped with multiple input options including HDMI, VGA, DVI-D, and more, alongside a built-in USB port, ensuring easy integration with a variety of devices. -
Optimized for digital signage
Designed specifically for digital signage applications, this LED-backlit LCD flat panel display features Anti Image Retention Circuitry (AIR) and a fanless design, making it ideal for continuous operation in public spaces. -
Superior visual quality
Boasts a 43-inch 4K UHD (2160p) display with a 5000:1 contrast ratio and LED backlighting, providing vivid, clear images from any viewing angle up to 178°. -
Smart energy consumption
Class G energy efficiency with a power consumption of 102 W in on mode, featuring a standby power consumption of just 0.5 watts, making it an eco-friendly choice for your digital signage needs.
- iiyama ProLite LE4340UHS-B1 43" Class (42.5" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/359271
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Commercial Use
- Yes - digital signage
- Matte black
- Platform
- Android
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), HDMI
- Technology
- AMVA3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- Power Consumption (On mode)
- 102 W
- Power Consumption Stand by
- 0.5 watt
- Energy Consumption per Year
- 201 kWh
- Dimensions (WxDxH) - without stand
- 96.82 cm x 6.09 cm x 55.94 cm
- Product Type
- Energy Class
- Class G
- 102 W
- Power Consumption SDR (On mode)
- 102 kWh/1000h
- 201 kWh
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Commercial Use
- Platform
- Android
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Landscape mode
- Design
- Fanless Design
- Dimensions
- Without stand
- 96.82 cm
- 6.09 cm
- 55.94 cm
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 5000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- Anti Image Retention Circuitry (AIR)
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 watt
- Speakers
- 2 x main channel speaker - 10 watt
Network & Internet Multimedia
- Functionality
- Streaming media playback
- Connectivity
- LAN
- Connector Type
- VGA input , 2 x HDMI input , DVI-D input , Audio input , RS-232 input , LAN , Infrared input , 2 x audio output , RS-232 output , Loop thru output , USB 2.0
- Batteries
- Cables Included
- DVI cable , HDMI cable , Serial cable
- Plug and Play, DDC-2B, CB, TUV Bauart, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 watt
