See the difference with the ProLite professional signage display. Featuring a slim bezel and an IPS LED panel for exceptional color and image performance, it offers businesses an easy and effective solution to successfully help them get their message across to the clients.
Enhanced audio experience
With a total output power of 20 W and a two-speaker system, this iiyama ProLite LE5540UHS-B1 delivers clear and powerful sound, enhancing any media content. -
Versatile connectivity
Equipped with multiple input options including HDMI, VGA, DVI-D, and USB 2.0, alongside audio input and output, LAN, and more, this display offers extensive connectivity for a variety of devices. -
Optimized for digital signage
Designed specifically for digital signage applications, this LED-backlit LCD flat panel display features a fanless design and Anti Image Retention Circuitry (AIR), ensuring reliable operation in various commercial settings. -
Superior visual quality
Boasting a 4K UHD (2160p) resolution on a 55-inch screen, combined with a high contrast ratio of 4000:1 and LED backlight technology, the display offers vivid, sharp images from any viewing angle. -
Smart energy use
Class G energy efficiency with a power consumption of 138 W in on mode and a standby power consumption of just 0.5 W, making it an energy-conscious choice for continuous operation.
- iiyama ProLite LE5540UHS-B1 55" Class (54.6" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/359258
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - digital signage
- Matte black
- Platform
- Android
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), HDMI
- Technology
- AMVA3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- Power Consumption (On mode)
- 138 W
- Power Consumption Stand by
- 0.5 watt
- Energy Consumption per Year
- 201 kWh
- Dimensions (WxDxH) - without stand
- 123.92 cm x 6.17 cm x 71.16 cm
- 16 kg
- Product Type
- Energy Class
- Class G
- 138 W
- Power Consumption SDR (On mode)
- 138 kWh/1000h
- 201 kWh
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Platform
- Android
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Landscape mode
- Design
- Fanless Design
- Dimensions
- Without stand
- 123.92 cm
- 6.17 cm
- 71.16 cm
- 16 kg
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Display Menu Language
- Czech, English, German, French, Italian, Russian, Spanish, Dutch, Japanese, Chinese
- Anti Image Retention Circuitry (AIR)
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm, 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 watt
- Speakers
- 2 x main channel speaker - 10 watt
Network & Internet Multimedia
- Functionality
- Streaming media playback
- Connectivity
- LAN
- Connector Type
- VGA input , 2 x HDMI input , DVI-D input , Audio input , RS-232 input , LAN , Infrared (IrDA) , 2 x audio output , RS-232 output , Loop thru output , USB 2.0
- Batteries
- Cables Included
- DVI cable , HDMI cable , Serial cable
- Plug and Play, DDC-2B, CB, TUV Bauart, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 watt
